Realistic Battery Life on iPad 3
This is a discussion on Realistic Battery Life on iPad 3 within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Just wondering what some of you more experienced Apple folks believe the expected battery life of the iPad 3 will be on average. The battery ...
Results 1 to 10 of 11
Like Tree4Likes
Thread: Realistic Battery Life on iPad 3
    246633
    27 times
    Sep 2012
    Minnesota
    508
    The battery is significantly larger than the iPad 2 but I'm sure the drain is much higher also.
    Is anything beyond 2 years unrealistic?
    Maybe trying to get it replaced on AppleCare + at the end of coverage is a good idea?
    Thanks...
    btw - I'm enjoying the heck out of this thing.
    iPad 4 - 64GB Black Wi-FI
    ZAG-Folio Bluetooth Keyboard Case
    iPad Addict
    95279
    65 times
    Sep 2011
    On a lake in Alabama
    1,330
    I believe the battery would hold up for 2 years plus, but there's many factors that could make it last or wear quicker. Like usage amount or storage temperatures to name a couple.
    My iPhone 4's battery has lasted almost 2 years now and it still holds just a good of a charge as day 1. I used it pretty heavily too, but like I said, there's many factors that could affect the life of the battery.
    You could always try and have the battery replaced when your 2 years is almost up, but Apple has specific software that checks the batteries condition and shows the worst battery life cycle you've gotten and the best cycle you've had. Just wanted to throw that in there.
    scifan57 likes this.
    iPhone 5 16GB Black (swapping between iOS 7 Beta and stock 6.1.4)
    iPhone 4 16GB CDMA Black (iOS 7 Beta)
    iPad 4th Gen. 32GB Black WiFi only (stock 6.1.3)
    246633
    27 times
    Sep 2012
    Minnesota
    508
    Quote Originally Posted by Darkstar2007 View Post
    Should of known Apple would cover their butts on this one.....
    What's the world coming to when you can't get a freebie once in a while.
    The $99 battery replacement isn't a bad deal, if needed.
    Guess I won't worry about it until the time comes, I was just wondering what to expect.
    Thanks...
    Moderator
    235421
    619 times
    Aug 2012
    Adelaide, South Australia
    3,671
    Quote Originally Posted by GHGFL View Post
    Charging is not the time as long as possible, should be stopped as soon as the battery protection circuit full charge, otherwise the battery will affect performance due to heat or overheating
    It's unfortunate that posts like yours, based on hearsay or random thoughts off the top of your head, or lack of simple research tend to spread misinformation and possibly some worry to iPad users. I won't reference the many clarifications you can get by simply searching on "iPad battery overcharging". Surely the following statement by Michael Tchao, Apple's Vice President of iPad Product Marketing should set your, and others' mind at rest:
    "Apple does in fact display the iPad (and other iOS devices) as 100% charged just before it reaches a completely charged level. At this point it will continue charging to 100%, then discharge and charge back to 100%. It will repeat this process until the device is unplugged. That circuitry is designed so you can keep your device plugged in as long as you will like."
    Silly persistent rumors of the iPad destroying itself by overcharging have been circulating long enough. Time they stopped!
    Regards, Andrew
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    246633
    27 times
    Sep 2012
    Minnesota
    508
    Quote Originally Posted by The OB View Post
    Regards, Andrew
    Thank You!
    I saw that post and knew it was completely inaccurate...........Thanks for setting things straight.
    Moderator
    235421
    619 times
    Aug 2012
    3,671
    No worries!
    All the best, Andrew
    246633
    27 times
    Sep 2012
    Minnesota
    508
    OK, I won't start another battery thread but have another question......
    When you plug the charger into an iPad that is shut off it powers on......not sure why but it does.
    Since I don't plan to use it when it's charging I again power it off with the cord attached.....it continues to charge this way.
    Does shutting it off and having it continue to charge affect the charge cycle in any way?
    Is the power adapter controlling the "smart charging" or is the iPad?
    Sorry for the questions but I'm anal <meticulious> about these things.
    Thanks....
    Moderator
    235421
    619 times
    Aug 2012
    3,671
    Quote Originally Posted by buerkletucson View Post
    Thanks....
    G'day buerkletucson. That's a very good question, and I've wondered that myself, which of course indicates I haven't got a bloody clue about it at all😳
    I have noticed that while charging, the standard supplied adaptor goes warm but when the iPad is charged up it gets cool again while still plugged in to power. So I guess there must be some regulator within the adaptor itself.
    The iPad3 battery which is large in area also gets warm mainly in a certain area of the iPad. Whether it's those little ions doing their thing charging all around the place in a much bigger iPad3 battery or whether the iPad is also regulating the battery, I'd be guessing. Hopefully one of the more techie people on this forum might answer both our questions.
    Regards, Andrew
    220553
    12 times
    Jun 2012
    Devon, UK
    152
    Interesting thread
    I'd suggest taking the experts' view on this, namely Apple's
    Apple (United Kingdom) - Batteries - iPad
    To quote just one part of that page...
    Charge Cycles
    A properly maintained iPad battery is designed to retain up to 80% of its original capacity at 1000 full charge and discharge cycles. You may choose to replace your battery when it no longer holds sufficient charge to meet your needs.
    Assuming one full charge cycle per day, your iPad battery will gradually decline from 100% capacity to 80% capacity over 2years 9 months of use. that's a nice long time & interestingly it is double the length of time that Asus say their Transformer range of tablet batteries wil last. Apple clearly use excellent batteries.
    • Apple - iPad3 16gb, iOS 6.0.1
    • Android - Samsung Galaxy S, CnM Touchpad II, Asus TF101, Lenovo A1, Motorola Xoom 2 ME, Samsung Galaxy Tab 2.0 7. (But not all at once )
    Banned
    173866
    Mar 2012
    79
    Can you please put that Software from Apple that you are talking about to Check the Battery Condition?
  1. Ipad 2 Battery life - What do you get?
    By Crush in forum iPad 2 Forum
    Last Post: 03-19-2013, 05:57 PM
  2. Ipad 2 battery life
    By zenny4 in forum iPad 2 Forum
    Last Post: 08-10-2012, 11:18 AM
  3. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  4. iPad battery life.
    By Electaguitar in forum iPad General Discussions
    Last Post: 12-28-2010, 01:40 PM
  5. Replies: 0
    Last Post: 03-25-2010, 01:15 AM
average battery life of ipad 3
how long does an ipad battery last before replacement
how long does ipad 3 battery last
how long does ipad battery last before you need to replace
how long should ipad 3 battery last
how many years will ipad battery last
ipad 3 average battery life
what is the average battery life of an ipad
