iPad 3: What is the maximum speed you have achieved /can achieve over WiFi?
This is a discussion on iPad 3: What is the maximum speed you have achieved /can achieve over WiFi? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I'm curious as to what is the maximum speed you have achieved over WiFi. Is there a predetermined maximum WiFi speed the iPad 3 just ...
Results 1 to 8 of 8
    180123
    Mar 2012
    Washington D.C.
    5
    I'm curious as to what is the maximum speed you have achieved over WiFi. Is there a predetermined maximum WiFi speed the iPad 3 just can't go above?
    I ask because I find it curious that on my laptop, which is about 3 months older than my iPad 3, I'm able to achieve 72mb download, twice the speed that on my iPad 3, which always maxes at 30mb.
    I recently replaced my router, which almost tripled the max speed I was able to achieve on my laptop, which used to be a maximum of 25mb, but It had almost no effect on my iPad 3, which speed increased only by 5 mb for a maximum of 30mb.
    Have any of you be able to achieve over 30mb on the ipad? Does anybody know what is the reason for this limitation? I always assumed that being my ipad 3 newer than my laptop, the wifi card would perform better but I see it is not the case.
    Below I'll post a couple of pics, one of the speed test on my laptop performed at speedtest.net, and the other one, a screen capture of the same test on my ipad, using speedtest.net's iPhone app.
    If anybody has any ideas as to why is there such a big discrepancy between the two, or if there is anything I can do to tweak the settings on the ipad 3 in order to improve the wifi performance, I'd appreciate it.
    Attached Thumbnails Attached Thumbnails iPad 3: What is the maximum speed you have achieved /can achieve over WiFi?-image-3485618977.jpg   iPad 3: What is the maximum speed you have achieved /can achieve over WiFi?-image-2863651247.jpg
    222629
    Jul 2012
    18
    iPad 3: What is the maximum speed you have achieved /can achieve over WiFi?-image-1925283500.jpg
    Here's my results and my actual broadband speed is 100 meg
    180123
    Mar 2012
    Washington D.C.
    5
    Quote Originally Posted by biskitbeetle
    <img src="http://www.ipadforums.net/attachment.php?attachmentid=27145"/>
    Wow, your results are almost identical to mine! I'm starting to believe no matter what your broadband speed is you will never reach more than 30 or 35 megs on the ipad. (My advertised speed is 75 megs but my desktop pc over ethernet always tests around 82)
    16407
    4 times
    Oct 2010
    Eastern UK
    141
    8 to 8.9 here.
    At my age it can be difficult to understand what others regard as simple!
    246633
    24 times
    Sep 2012
    Minnesota
    481
    I have dial-up........
    I'm getting 28/4.2 Mbps............this is with 20MB service.
    I'm paying less and getting almost as much as you high rollers.
    iPad 4 - 64GB Black Wi-FI
    ZAG-Folio Bluetooth Keyboard Case
    213285
    76 times
    Jun 2012
    St. Louis, USA
    526
    3 meg DSL here, via cheap 802.11n router. Seems like I'm getting what I paid for.
    Attached Thumbnails Attached Thumbnails iPad 3: What is the maximum speed you have achieved /can achieve over WiFi?-image-1676185444.jpg
    49720
    277 times
    SC
    5,365
    iPad 3 has a weaker processor than most laptops. Also, the antenna environment is very different too.
    30mbps is plenty for anything you need to do on an iPad. It could be capped just to ensure the CPU is not taxed too much so it can service other tasks.
    180123
    Mar 2012
    Washington D.C.
    5
    Quote Originally Posted by AQ_OC
    Interesting. That never occurred to me. The culprit being some cap set by apple as you say above makes a lot of sense.
  1. iPad2 Wifi N speed 1/2 of what it should be?
    By IrvSp in forum iPad 2 Forum
    Last Post: 08-16-2012, 11:44 PM
  2. Replies: 13
    Last Post: 03-20-2012, 09:29 PM
  3. iPad WiFi to Router Speed?
    By jdag in forum iPad OS
    Last Post: 04-16-2011, 05:37 PM
  4. Beware of the FCC WiFi speed test app
    By Billee in forum iPad General Discussions
    Last Post: 09-16-2010, 06:27 PM
  5. Wifi vs 3G wifi speed/reception
    By CPMS in forum iPad General Discussions
    Last Post: 05-03-2010, 10:25 AM
ipad 3 download speed
ipad 3 max wifi download speed
ipad 3 max wifi speed
ipad 3 wifi speed
ipad 3 wifi speed cap
ipad 3 wifi top speed
ipad wifi speed
max wifi download speed ipad 3
max wifi speed ipad 3
maximum wifi speed ipad
maximum wifi speed ipad 3
wwhat is the wifi connection speed for ipad
