Results 1 to 7 of 7
Thread: Battery
    246636
    Sep 2012
    10
    Battery
    My ipad 3 battery is not performing wel...before i goes to sleep my battery was 65% and after i wake. Up in morning my ipad's battery was 57%.
    I have checked therre was no running application...why my battery has decrease withouut any use...
    Plzzzz help.
    250304
    Oct 2012
    egypt
    wifi opened?
    246636
    Sep 2012
    10
    Quote Originally Posted by bubakazouba
    wifi opened?
    No i use cellular data no wifi........
    7512
    Jun 2010
    Upstate NY
    73
    cellular is probably worse than wifi for battery usage, particularly if you have a weak signal.
    try turning off your cell radio each night. or switch to wifi.
    Moderator
    235421
    151 times
    Aug 2012
    Adelaide, South Australia
    2,140
    Quote Originally Posted by Navneet Nayak View Post
    Plzzzz help.
    What you may be seeing is that your battery percentage indicator up top is not being accurate. Apple recommend that each month you should fully charge the battery, then run it down to empty and then fully recharge it to realign the ions (or whatever the little beggars do). Do this regularly for the health of your battery, (well the iPad's also)
    Other things you could look to do:
    * Clear the Apps tray at the bottom after double-pressing the Home button. You never know what juice-sapping stuff may linger there eg games. In fact it is good practice to, say, weekly reset your iPad tidying up memory etc. (Press and hold the Home Screen and Off buttons until the Apple logo appears and when the Home screen returns your iPad has had a reboot which is healthy)
    * Go through your iPad Settings and slide the WiFi and Bluetooth settings to Off and check what other automatic monitoring features are on.
    * Go to Apple's User Manual re Batteries on Apple - Batteries - iPad for what Apple has to say re battery maintenance.
    * Find a good Batteries App that assists with recharging. I use free Battery Doctor plus which shows your charging history, reminds you when to fully recharge, gives tips etc.
    The above will not do any harm but will help for a healthy battery.
    Regards, Andrew
    ​Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Everybody please read the forum rules--->
    iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    216646
    2 times
    Jun 2012
    Cold House, Xibalba
    61
    Plzzzz help.
    'Without any use' might not be what's happening. If the data connection is open, the apps keep on looking for data for themselves. And if the connection takes long, the more the battery drains. IPad doesn't sleep, you know...
    Sent from my GT-I9000 using my brain.
    246633
    24 times
    Sep 2012
    Minnesota
    481
    Turn the iPad off will save battery life, especially overnight...........takes less than 1 minute to boot.
    A fresh boot is always a good thing anyways.
    iPad 4 - 64GB Black Wi-FI
    ZAG-Folio Bluetooth Keyboard Case
  1. Battery
    By kluppy in forum iPad Help
    Last Post: 08-16-2012, 10:43 AM
  2. How often do u charge battery to save battery life
    By eddiethebhoy in forum iPad General Discussions
    Last Post: 04-24-2012, 04:29 PM
  3. Battery
    By Larrybe in forum iPad Help
    Last Post: 01-02-2011, 11:07 AM
  4. Battery in IOS 4.2.1
    By skatealex2 in forum iPad OS
    Last Post: 11-29-2010, 07:07 PM
battery
ipad battery goes up after reboot
why the ipad battery never go up
