Problems with IOS 6?
This is a discussion on Problems with IOS 6? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; It is just me or anyone had an issue with ios6 battery life? My ipad drain battery much faster after updating to ios6...
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
Like Tree1Likes
Thread: Problems with IOS 6?
  1. #11
    225841
    Jul 2012
    Bandung, INA
  3. #12
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Quote Originally Posted by kuyarawa View Post
    You should never be experiencing significant additional battery drain after installation of a new OS. If you are, it indicates a problem with the upgrade process.
    You are best adviced to take a backup, restore the device using iTunes with a clean install of IOS 6, then restore your backup and allow your content to sync on there again from iTunes.
    That normally gets rid of any problems that occurred due to the update process, which doesn't always deal with all the little anomalies which can be on each persons device after using it for a while
    Good luck.
    kuyarawa likes this.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  4. #13
    225841
    Jul 2012
    Bandung, INA
    Quote Originally Posted by f4780y View Post
    Good luck.
    I do exactly as you said last night, backup > restore device via itunes for a clean install of ios6 > restore backup > sync content again.
    After finish everything, I just leave my ipad charged until morning (battery 100% charged). And I'm using my ipad as usual.
    And now 3:00 pm here (8 hours with battery) the battery indicator say 95% which is much better that yesterday. This is work! Thanks for advice!
  5. #14
    Moderator
    235421
    616 times
    Aug 2012
    Adelaide, South Australia
    3,654
    [QUOTE=kuyarawa;681596]
    Sent from my iPad using Tapatalk[/QUOTE
    Good to see that. The iPad is one of the best tablets you can buy as far as battery life is concerned. After about 4 hours use every day, I recharge every second day with about 40% still remaining. Not too shabby!
    Also a good idea to at least once a month run down a fully charged battery to say 10 to 20% and recharge again. This gives a more accurate reporting of the battery's state of charge as shown at the top of the screen. ( That teaches those little lithiums or polymers or ions, whatever they are called, to shape up and get into line)
    Regards,Andrew
  6. #15
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    I do exactly as you said last night... This is work! Thanks for advice!
    Glad to be of service, and good to hear it resolved your issue.
  7. #16
    11919
    10 times
    Aug 2010
    Virginia, USA
    732
    No, no issues at all with iOS 6 on either our new iPads or our iPhone 4S and 5. The only exception may be the Maps app which is the only thing Mr. Cook addressed in iOS 6 but I haven't used the old one anyway after I obtained GPS Drive which works just fine.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
  8. #17
    116711
    Oct 2011
    28
    I had a problem my new iPad would not stay connected to my Wi-Fi network, Apple replaced my iPad and my iPhone 4S. the problem was still happening. I called Apple back and we went into my router and change the encryption type from both to one or the other and it fixed it and thank God on the new iPad I have iOS 5 back.... I have not had a problem with staying connected to Wi-Fi since I changed the encryption type off of both.
  1. Set up problems
    By jkingrph in forum iPad 3 Forum
    Last Post: 06-06-2012, 10:53 PM
  2. Problems
    By dphill33 in forum New Member Introductions - Site Assistance
    Last Post: 05-16-2012, 11:03 PM
  3. 4oD problems
    By DC1962 in forum iPad Help
    Last Post: 03-09-2012, 07:29 AM
  4. App problems with 4.3?
    By Sportsgram in forum iPad General Discussions
    Last Post: 03-15-2011, 01:45 AM
  5. SSH problems
    By zachdrago in forum iPad Hacking
    Last Post: 07-01-2010, 05:38 PM
apple i06 issues
apple i06 problems
i06 issues
i06 problems
i06 update issues
io6 battery drain
ipad i06 problems
ipad i06 update problems
