Jailbreak iPad 3 stuck in recovery mode from trying to upgrade to IOS 6 without DFU..
This is a discussion on Jailbreak iPad 3 stuck in recovery mode from trying to upgrade to IOS 6 without DFU.. within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi All, Just wondering if this problem was resolved, and if so how it was done? I have the same problem essentially. I think I ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 11 of 11
  1. #11
    257806
    Nov 2012
    UK
    Similar issue on I pad 2 - error -1
    Hi All,
    I have the same problem essentially. I think I scrambled my Ipad 2 (not 3) when trying to use it to tether to my laptop using tetherMe app from cydia, and pulled the plug out mid-sync
    Downloaded Tiny Umbrella and followed all the steps, however the box that your supposed to un-check was blocked out and already unchecked anyway.
    I've updated my iTunes and iPad firmware to the latest (6.0.1) and went to restore and I forgot to put it in DFU mode. Now whenever I attempt to re-install it looks like it is about to be completed and then I get the Error - 1 message.
    Have tried to re-do all steps, (and also tried to boot it out of recovery via tiny umbrella - which fails) I think the key issue from following the steps is that now I can't seem to access DFU mode either.
    Have also tried to restore via a different laptop which also lead to the same problem so it must be related to the ipad, and not the settings on the computer?
    Any help would be greatly appreciated.
    Thanks,
    Mitch
    (sorry if this is in the wrong thread, didn't want to re-post when this is very very similar to my circumstances (looks like we both went wrong when not puting in DFU mode)
    The below is very worrying!!
    Error 1 or -1
    This may indicate a hardware issue with your device. Follow Troubleshooting security software issues, and restore your device on a different known-good computer. If the errors persist on another computer, the device may need service.
  1. Help! Ipad Stuck on Recovery Mode
    By ecthelionv2 in forum iPad Hacking
    Last Post: 05-23-2012, 09:55 PM
  2. My iPad 2 is stuck in recovery mode!
    By Shushant in forum iPad OS
    Last Post: 02-04-2012, 02:57 AM
  3. IPad 1 Stuck in Recovery Mode
    By aghicklin in forum iPad Help
    Last Post: 11-04-2011, 03:10 PM
  4. Ipad stuck in recovery mode
    By VaibhavRohan in forum iPad Hacking
    Last Post: 10-03-2011, 02:37 AM
  5. Ipad Stuck in Recovery Mode
    By AJMC in forum iPad Help
    Last Post: 06-07-2011, 10:37 PM
dfu ipad 3
dfu mode jailbreak ipad 3
exit recovery mode ipad 3
how to get ipad 3 out of recovery mode without restoring
ipad 3 stuck in recovery mode
ipad stuck in recovery mode after jailbreak
jailbreak ipad in recovery mode
jailbreak ipad recovery mode
jailbroken ipad 3 stuck in recovery mode
jailbroken ipad in recovery mode
jailbroken ipad stuck in recovery mode
stuck in recovery mode ipad 3
