Apps stuck on "waiting". Help.
This is a discussion on Apps stuck on "waiting". Help. within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Originally Posted by lenny12 Hi there I am trying to upload new apps and since this morning all they say are waiting...? I have turned ...
Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 42
Like Tree2Likes
Thread: Apps stuck on "waiting". Help.
  1. #21
    Moderator
    235421
    616 times
    Aug 2012
    Adelaide, South Australia
    3,655
    Quote Originally Posted by lenny12
    Hi there I am trying to upload new apps and since this morning all they say are waiting...? I have turned it on and off as well as resetting and they are still waiting. They have been like this sine this morning! Can someone advise me as to what to do please? I have no upgrades that need doing.
    Lenny, this may be a long shot but if one is running out of bullets that is worth a try? Have you signed in with more that one account in iTunes? That is, when downloading apps is that with the same account related to the purchased/free app? I know there is nothing more annoying that getting airy/fairy advice after you have seemed to try everything. But this is just another attempt to help. The answer can't be too far away as this forum attempts to address every problem and question.
    Regards, Andrew
    Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Check out the rules~ http://www.ipadforums.net/forum-rule...ease-read.html
    iPad3 64gig black, much unused PC Win 8.1 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
  3. #22
    246200
    Sep 2012
    12
    Hi Andrew, I only have the one account for my iTunes. However you've just reminded me that it never asked me for my password but that could be due to the system upgrade right? Thanks
  4. #23
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,851
    That's right. Once you are on iOS 6 you don't need to supply your password for updates. And Andrew is right. One way or another, we will get to the bottom of this. It just might take a while.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
  5. #24
    48665
    951 times
    Brisbane, Australia
    23,505
    Quote Originally Posted by KevinJS
    Kevin....you're on IOS6? Has the iTunes app changed? I haven't updated as yet, still debating on it and other things. But Lenny has said he doesn't have the downloads tab.
    I've also heard that certain settings have changed too, it might be an idea to check if anything has changed for the app store settings. Just a thought here.
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
  6. #25
    85546
    579 times
    Aug 2011
    Edmonton AB Canada
    9,851
    Quote Originally Posted by leelai
    Yes, I'm on iOS 6 on the iPad, and I kept iOS 5.1.1 on the phone so I have access to both versions. I'll check iTunes and get back to you. I know the App Store has changed radically. Example, you can no longer gift an app.
    Here's a screenshot of the iOS 6 iTunes Store. No downloads tab, as you say.
    And here's the iOS 5.1.1 version.
  7. #26
    48665
    951 times
    Brisbane, Australia
    23,505
    Lenny, have you downloaded anything in iTunes recently?
    Might be an idea to sign out of the App store and back in too.
  8. #27
    247341
    Sep 2012
    Denmark
    I have same problem and have tried all suggestions on this and other forums with same results of no fix. Tomorrow I will go down to local apple store and see if they can re-image.
  9. #28
    248230
    Oct 2012
    East coast
    I am having this same problem. Since last week new apps and updates for existing apps won't download actually the timing seems to have coincided with ugrading to IOS6 but don't know if that is just a coincidence or not. And, pressing on the app for three seconds does make it jiggle but the waiting apps do not have an X in the corner so that I can delete them. Even worse one of the apps I was trying to update is one I just recently downloaded and was just learning how to use it and very much liked it and now that it is in waiting status I cannot use it. I have only had my iPad for about 1 month and I'm a very frustrated user right now. Does anyone know how to delete these apps that are now in limbo?
  10. #29
    48665
    951 times
    Brisbane, Australia
    23,505
    I've noticed sometimes that deleting History and Cookies can sometimes fix problems that I have in other areas.....go to Settings - Safari and clear them here.
    I don't know if it will make the difference here but it is worth a try.
  11. #30
    248977
    7 times
    Oct 2012
    88
    Didnt want to create a new thread so Im gonna use this one.
    Today I tried installing "Box" from the app store. My ipad rebooted during it and now Ive go a ghosting icon that is forever waiting. Ive tried the below and still have the same problem.
    Reset all settings
    signed out and back in to app store
    erased all history and cookies
    installed the app through itunes on my pc - This causes it to freeze on installing
    Erased the app in settings>general>usage>delete app
    Erased the app in itunes
    Rebooted about 30 times
    Im on 5.1.1 and I do not want to go to 6.0. I am jailbroken so Im wondering if I use ifile to delete wahateve file I need to, then maybe itll go away?
    Really hoping someone can help me out here.
  1. Apps stuck in "Waiting" mode
    By dredmond in forum iPad Help
    Last Post: 09-27-2012, 03:20 PM
  2. Apps update stuck on "waiting' after updating to latest software on iPad
    By Mccavity in forum New Member Introductions - Site Assistance
    Last Post: 04-08-2012, 08:49 AM
  3. iBooks stuck 'waiting'
    By daktari in forum iPad General Discussions
    Last Post: 02-09-2012, 07:08 PM
  4. Stuck on waiting
    By Yan2011 in forum iPad Apps
    Last Post: 12-20-2011, 11:02 AM
apps say waiting on ipad
how do you delete an app that is stuck waiting on an ipad
ipad app waiting stuck
ipad apps say waiting
ipad apps stuck on waiting
ipad apps wont download says waiting
ipad update waiting
uploaded latest update on ipad and all apps say waiting
