Do you think it is right/healthy making adjusments by using Asus's software to solve iPad's "Not Charging" problem ? Will it be harmful for my iPad ? Is there any possibilities ?
Thank you.
This is a discussion on Making Adjustment for "Not Charging" Problem within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Do you think it is right/healthy making adjusments by using Asus's software to solve iPad's "Not Charging" problem ? Will it be harmful for my ...
Thank you.
No. The iPad will draw the power it needs, and stop when it's had enough. I would be more worried about damaging the computer by sending more power to the USB port, but no-one has reported any issues yet, and the Asus software seems quite popular.
Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
Thank you so much. The important thing is iPad, don't care about the computer![]()
You and me both. If my PC were to "accidentally" explode, I would have justification for buying an iMac.Originally Posted by Esquire
What iPad "not charging problem?" I've never had any such problem with ipad 1, iPad 2, or my New iPad.
If my Irish Wolfhound doesn't like you neither will I.
2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
When you plug in your iPad to your PC, it says "Not Charging" at the top of the screen. Because Pc's USB ports don't have enough power to charge iPad. But you can change power limit by using Asus software. My question was about this. Is it harmful to change power limit ? Probably no, for iPad. Maybe, for Pc.
Why change anything? The iPad charges perfectly with the charger supplied with it. Simply use that charger.
