Something loose when I tap top right of back?
This is a discussion on Something loose when I tap top right of back? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi, my new iPad is only a week and a half old. But I noticed that when I tap the back casing in the top ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    139607
    Dec 2011
    Ascot, Berkshire, England
    21
    Hi, my new iPad is only a week and a half old. But I noticed that when I tap the back casing in the top right (camera side) I hear a slightly metallic sound as if something is loose inside. I'm very nervous and worried about this and obviously whether it's normal or not I ought to not be tapping it. But I can't help but wonder if it's ok.
    So is this a recognised thing and/or do your iPads do this?
    Cheers
    226877
    19 times
    Jul 2012
    360
    A rare case, this doesn't normally happen on normal iPad Devices, it might require a check-up, please ask or go to your provider and discuss the issue, do it while you still have the warranty.
    "Utilize your day, make it as useful and fun as it can be."
    If you like a post, give a second to press the like button, people work hard to supply you with information that you need, show them a little appreciation...
    It's always handy reading this >>> Forum Rules <<<
    --Allen Salar--
    49720
    277 times
    SC
    5,365
    Not normal. Seek a return/exchange.
    139607
    Dec 2011
    21
    Thanks guys, that's sensible, off to apple store tomorrow are they usually good with returns?
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Quote Originally Posted by Gordon49 View Post
    Absolutely. They have an excellent track record. Any fault is normally sorted by swapping out the unit with a new one on the spot. You should be golden
    Moderator
    131244
    635 times
    Dec 2011
    Regina,Canada
    14,644
    Before you take your iPad in to the Apple store,do a backup. Then,when you bring the replacement iPad home you can set it up from the backup you made and it will have all the content and apps that the original iPad did.
    139607
    Dec 2011
    21
    Thank you yes, I had already thought about that.
    139607
    Dec 2011
    21
    Ok. Thanks for your help on this guys.
    Sad I won't be able to keep this beauty that I've already "bonded" with. But even though its only a week and a bit old and should have no effects yet from my use at least I'll be getting a nice fresh one that I can take care of straightaway. I fear that I may have scratched the screen on a few occasions anyway :L despite my intense care so far. I guess obviously some employee at the Foxconn factory didn't do their job correctly.
    So anyway, with regards to the turn around process what should I do to prepare it? If I do a backup, will I be able to continue where I left off on my new device with exactly the same settings and files and photos and emails etc? Then after a backup would it be an idea to erase all data - just wanna check before I do the backup and comtinue with that. I won't be doing that till tomorrow since I'll need to use it in the morning before I get to the store.
    Ok, so I've removed my sim card. Taken off the case and smart cover and put them all away. Got the box, re-packaged it with the leaflet, sim remover tool and charger and USB. Ill continue to use it tomorrow then before I leave I'll iCloud back it up, erase all data and just give it a clean to show I take care of it and repackage everything. Take it there, present it and explain the problem. Should give me a new one trouble free. I take new one back, unbox it again put sim card, case and smart cover back, setup process and choose to restore from a backup. And then I should be using the new one just like the old one, and I wouldn't notice a difference at all between the two, except the rattle will be gone. Cool!
    Sorry about the long post but is there anything else I should do?
    Moderator
    131244
    635 times
    Dec 2011
    Regina,Canada
    14,644
    Just enjoy the replacement when you get it!
    226877
    19 times
    Jul 2012
    360
    Yes, you will have the same settings files and photos, I'm not really sure with the emails since I NEVER used the iPad for e-mails.
    Not really necessary as far as I'm concerned. But if you want to then go ahead. Apple has a policy on user confidentiality
    And I guess that's about it.
    --Allen Salar--
  1. Replies: 4
    Last Post: 05-19-2012, 04:49 AM
  2. Will I loose all my apps ?
    By Andy Loba in forum iPad General Discussions
    Last Post: 10-10-2011, 08:21 AM
  3. What do I loose installing "pdf pATCHER 2" ?
    By peled in forum iPad Hacking
    Last Post: 07-20-2011, 12:10 PM
  4. Worried that i i+might loose ebook after sync
    By garfy in forum iPad Help
    Last Post: 06-18-2011, 11:29 PM
  5. earphone jack..... loose?????
    By SheerLuckHolmes in forum iPad General Discussions
    Last Post: 04-12-2011, 09:39 PM
ipad 2 loose at top
ipad back cover loose
ipad tap top page
loose ipad back cover
rattle
something is loose in ipad
something is loose in my iphone 5 tap
something loose in ipad 2
something loose in iphone 5
something loose in my iphone when i tap it
something loose ipad 2
sumthing loose in ipad 2 cover
