Results 1 to 10 of 14
    227873
    Jul 2012
    Thumbs down Ipad 3 Wont Connect to my Home Wifi
    Hello All.
    i just got a brand new ipad here friday..
    i have been fighting for hours. and talked to Apple Care for like 3 hours now. ive done everything etc with reseting the ipad and the networks settings
    for some reason my wifi wont connect to my Ipad 3 i put in the right SSID in. and the right password.. and i have done everything Apple have told me.. and it still dont work. i dont know how to fix this at all.. on my Iphone it works perfect. but not the ipad.
    and i have the Netgear N900 WDR4500 can it be my router
    can someone please help. can it be my ipad do i really need to return it again ???. is there any fix for this. ?
    222071
    3 times
    Jun 2012
    U.K
    212
    I'm sure you have already checked this but ...
    Have you ensured that you are entering you pass code with the caps lock on? These codes are case sensitive.
    227873
    Jul 2012
    yeps all of it
    85546
    517 times
    Aug 2011
    Edmonton AB Canada
    9,720
    I would try giving the router a reboot. Unplug it and leave it off for a few minutes before plugging it back in.
    227967
    Jul 2012
    6
    I think it's also possible that your security type is not supported, have you tried changing that as well?
    180142
    Mar 2012
    20
    Turn the security off on your router for a few minutes. It if works then, it's the security, if not, security isn't an issue, turn it back on (in either case turn it back on when you are done with the test) I had to return my first iPad 3 because the 5ghz wireless a/n wasn't working. Unit was checked at the Apple Store and they confirmed that side of the radio was dead. Try to connect to both the 2.4 and 5 ghz band.
    29813
    20 times
    Quebec
    642
    Most common issue in this case is the MAC address filtering that is activated in the router. Check if it is activated and turn it off for testing. If it works, then you just have to add your iPad MAC address to the list before turning it on again.
    iPhone 4S 16Gigs 5.01
    iPad 1 16 Gigs Wifi 5.01
    Canada / Rogers
    216762
    Jun 2012
    24
    I have the same router, use the highest security offered, and connect with Netgear57-5g without any problems. As a dual router, my iPhone 4 will only connect to the 2.5, not the 5G. I hope you solve your problem. I posted this to ensure you that the N900 does work with the new IPad.
    227873
    Jul 2012
    i had a chat with netgear everything works now. it was the acess list. that was blocking the ipad to connect
    but thanks for all your reply and help
    248425
    Oct 2012
    Serbia, Belgrade
    Help! Help! Help!
    I have the same problem! What should I do?
  1. Replies: 1
    Last Post: 05-25-2012, 01:32 PM
  2. Wont connect to wifi via router
    By lbowsman in forum iPad Help
    Last Post: 05-04-2012, 05:00 AM
  3. My ipad2 wont connect toy home wifi
    By apilotsgirl in forum iPad 2 Forum
    Last Post: 11-27-2011, 09:03 AM
  4. Cannot connect to home wifi
    By jazzbo in forum iPad Help
    Last Post: 09-25-2011, 05:43 PM
  5. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
connecting ipad3 to wifi
how to connect ipad 3 to wifi
how to connect ipad3 to wifi
how to connect wifi to ipad 3
ipad 3 how to connect to wifi
ipad 3 not connecting to wifi
ipad 3 will not connect to wifi
ipad 3 wireless n
ipad 3 wont connect to wifi
my ipad wont connect to wifi
why wont my ipad 3 connect to wifi
why wont my ipad connect to wifi
