Ipad 3 Wont Connect to my Home Wifi
This is a discussion on Ipad 3 Wont Connect to my Home Wifi within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Originally Posted by Ivana7 I have the same problem! What should I do? Like other guys said: disable network security and try to connect (DHCP ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
  1. #11
    233944
    Aug 2012
    71
    Quote Originally Posted by Ivana7 View Post
    Like other guys said: disable network security and try to connect (DHCP enabled). If you can't check if the MAC address exclussion rules are activated and whether your iPad is on the list or not.
  3. #12
    Moderator
    235421
    119 times
    Aug 2012
    Adelaide, South Australia
    1,887
    Ivana, it could be the same router problems as discussed above, BUT don't assume it. Have a go at this.
    Open Settings, then General, then Network and tap WiFi. Then tap the blue arrow next to the wireless router you are connected to. Then tap "Forget this Network". Go back to WiFi and re-enter the network information originally required by your Internet Service Provider. That should do the trick.
    Let us know if that worked. If not, try this. Go to General then tap Reset, then tap "Reset Network Settings". Reboot your iPad and connect to your Internet Service Provider as before. I hope that works for you. If still no good, post your result. There are solutions out there!
    Regards, Andrew
  4. #13
    249423
    Oct 2012
    18
    how to solves this . plz i can't do it
  5. #14
    250703
    Oct 2012
    Re: Ipad 3 Wont Connect to my Home Wifi
    I could get it to work for a short period of time by resetting network settings.
    Any way you fix this so I don't have to reset every day?
    Sent from my Galaxy Nexus using Tapatalk 2
  1. Replies: 1
    Last Post: 05-25-2012, 01:32 PM
  2. Wont connect to wifi via router
    By lbowsman in forum iPad Help
    Last Post: 05-04-2012, 05:00 AM
  3. My ipad2 wont connect toy home wifi
    By apilotsgirl in forum iPad 2 Forum
    Last Post: 11-27-2011, 09:03 AM
  4. Cannot connect to home wifi
    By jazzbo in forum iPad Help
    Last Post: 09-25-2011, 05:43 PM
  5. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
connecting ipad3 to wifi
how to connect ipad 3 to wifi
how to connect ipad3 to wifi
how to connect wifi to ipad 3
ipad 3 how to connect to wifi
ipad 3 not connecting to wifi
ipad 3 will not connect to wifi
ipad 3 wireless n
ipad 3 wont connect to wifi
my ipad wont connect to wifi
why wont my ipad 3 connect to wifi
why wont my ipad connect to wifi
