Hi, my IPad-3 does not get charged from my Laptop, whereas, it only gets charged through 10W power cable. I would appreciate if anybody could give me the reason for not charging. Thanks
This is a discussion on IPad-3 Charging from my Laptop through USB cable within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi, my IPad-3 does not get charged from my Laptop, whereas, it only gets charged through 10W power cable. I would appreciate if anybody could ...
USB does not supply sufficient power to charge the iPad. It will charge very slowly, but the charging symbol will not show up.
Presently using: Apple iPhone 4 | Apple iPad 2 | Apple MacBookPro | AppleTV | Apple AirPort Extreme
I should add that USB3.0 supposedly supplies enough power, but my computer only has USB2.0, so I can't vouch for that.
hi Kevin, thx for yr advice. when I charge my IPad thru my Laptop, it just write on the top right corner Battery sign 'Not Charging'. It means, it does not get charged.
You will always see "Not Charging" when the iPad is plugged into USB2.0, however it will charge sufficiently to maintain charge, or at least slow down the discharge. Eventually, it might even fully charge, but it is going to be a slow process, even if you have the screen turned off.
USB 3.0 port here. But not charging. Any luck with others here with USB 3.0?Originally Posted by KevinJS
When charging using USB 3.0 from my HP DV7 laptop:
- SYS Activity Manager Plus indicates that it IS Charging
- The screen battery indicator says "Not Charging"
SYS Activity Manager Plus (for Memory, Processes, Disk, Battery, Network, Device Stat & Performance Monitoring) is one of the relatively few paid apps that I have bought yet (and well worth the 99 cents).
There is an adapter cable for cheap on amazon that "upgrades" to allow for USB 3.o charging.....works with stock ipad cable. $7
BoxWave iPad Charging Adapter, Allows You To Charge Your iPad 3/iPad 2/iPad on ANY Computer or USB Hub for Compatibility With Generic Chargers
Works great
Hmmm. Interesting. Does the battery percentage increase over time?Originally Posted by Dougsap
