IPad-3 Charging from my Laptop through USB cable
This is a discussion on IPad-3 Charging from my Laptop through USB cable within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I actually just bought a new laptop about a month ago for $350 from Best Buy that has totally blown me away. It is an ...
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    33347
    12 times
    Feb 2011
    Mississippi
    260
    I actually just bought a new laptop about a month ago for $350 from Best Buy that has totally blown me away. It is an Asus K53 and it has a USB 3.0 port but it also has a USB port that does what is called "Quick Charge" and it does charge my new iPad and will even charge it while the laptop is sleeping or turned off. This is a great feature and has come in handy on a couple of occasions while sitting in a hospital room with limited plug in accessibility.
    So look for this feature when shopping for new laptops!
  3. #22
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Quote Originally Posted by Mickeylittle
    How long does a full charge take compared to the time it takes with the normal charger?
  4. #23
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Quote Originally Posted by scifan57 View Post
    I haven't tested that as I've only used the charging feature 2-3 times and probably had 40-50% when I plugged it in to charge. From the little experience I do have it has seemed to work as good as the wall charger though.
  5. #24
    222271
    Jun 2012
    67
    Quote Originally Posted by Bosvaark
    I was correcting what you said in your post as it is misleading.
    " USB ports don't produce a high enough output voltage for the iPad to recognise a charge"
    Incorrect : voltage is constant its amps that increase charging rate , in this case 100ma on a standard USB port is not enough hence the trickle charge
    "with your laptops charger input being about 5v ...."
    Incorrect : Laptop power supplies range from 15-20 volts not 5V
    Yes I know all of this but it's much simpler to quote it the way I did as most people have no Idea what amps and ma are, not making a big difference as they're not in need to know the outputs, if they were I would've stated them. Thanks for the response.
    The iDevice Guru
  6. #25
    212021
    2 times
    Jun 2012
    NY
    87
    Quote Originally Posted by Mickeylittle View Post
    Gigabyte have a desktop that provide a similar feature. According to the spec their mb is capable of delivering 3X the current of a standard usb 3.0. This means that it is capable of charging a 13.5 W device. If this device is the Ipad 3 then the charging time will result to 3 - 4 hours based on my calculation. This is more or less faster compared to the Ipad 3 charger unit can provide.
  7. #26
    229108
    Jul 2012
    6
    Hi everyone im new to this whole thing jus purchased my ipad3 last week& it's been so complicated!!. Firstly does it mean I can't sync my iPad to my iTunes library since its not charging? Also i cannot see "my iPad" appear on my iTunes library.
    Pls any advice wud be much appreciated. Thnx
  8. #27
    222271
    Jun 2012
    67
    Quote Originally Posted by Breeodi
    Your iPad should connect wirelessly, ensure you're signed in on both devices on the same email account, also ensure you're connected to the Internet on both devices.check that you've successfully and fully set up your iPad. Anything else just let me know, I'll do my best.
    Add me on Edited by Moderator - No social network addresses, please read the forum rules for live support!
    The iDevice Guru
    Last edited by Gabriel1; 07-20-2012 at 05:34 PM. Reason: Removed a kik (apparently an app) social networking address
  9. #28
    224179
    Jul 2012
    To connect wirelessly to iTunes on your computer, you must have your iPad connected to the mains charger.
    Took me a little reading to get it working.
  10. #29
    229108
    Jul 2012
    6
    Quote Originally Posted by iDeviceGuru
    The iDevice Guru
    Thanx ideviceguru would try it!
  11. #30
    229108
    Jul 2012
    6
    Quote Originally Posted by alan roberts
    Thnx Alan
  1. Replies: 28
    Last Post: 10-10-2012, 05:49 AM
  2. Longer (in length) charging cable for iPad 2?
    By GAMESHARQ in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-05-2012, 07:00 PM
  3. Charging speed of USB cable
    By innkuang in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-29-2011, 07:40 AM
  4. Looking for Ipad charging cable 6ft
    By Sshewa1 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-31-2011, 12:29 PM
  5. 12V charging cable....OK with iPad ?
    By EODtech in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2010, 10:35 AM
can ipad be charged from laptop
how to charge ipad 3 on laptop
how to charge ipad from laptop
how to charge ipad with laptop
ipad 3 not charging on laptop
ipad charge screen
ipad not charging on laptop
ipad not charging on my laptop
