Charging the battery
This is a discussion on Charging the battery within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi to all, how often do you charge your battery? Each time you put it down? Overnight? Can you charge it when its half flat? ...
Results 1 to 10 of 20
Like Tree2Likes
Thread: Charging the battery
    221276
    Jun 2012
    France
    26
    Thanks for any replies.
    I PAD 16 GO WIFI
    220048
    Jun 2012
    8
    Go in to app store and download battery doctor,it's great. Let's you kno when to do full charge,tips on how to conserve battery life etc.
    11919
    9 times
    Aug 2010
    Virginia, USA
    721
    I charge mine when it gets down to 20-25%. Same as I did with my iPad and iPad2. It charges to 100% in about 3-4 hours but I just plug it in when I go to bed and unplug when I get up.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    218977
    Jun 2012
    25
    Hi is it ok to leave charging overnight then? I thought you shouldn't leave it charging for too long, but then what do I know I have only had my iPad for a couple of months, incidentally it seems to take more than 4 hours to charge fully.
    217338
    Jun 2012
    10
    Quote Originally Posted by stargirl1
    Which Battery Doctor works for you? There are several different ones.
    52510
    65 times
    May 2011
    Good ol' Midwest
    1,841
    Quote Originally Posted by lindy123
    I leave mine always plugged in, unless i leave the house with it.
    Sent from my White iPad 4.
    217338
    Jun 2012
    10
    I've been wondering about this too. Two different reps at the apple store told me two completely different stories I about batteries and charging. I looked on Apples site and found information but still have questions. Where is the definitive web site about charging? Thx.
    196878
    4 times
    Apr 2012
    Columbus, GA
    63
    Don't over-think charging. The battery and charging circuitry are amazingly sophisticated, making it very hard to screw it up.
    Charge it when it needs it, or when you have time. And once a month (more or less), run it all the way done and then charge it fully, to recalibrate the battery level metering.
    Or do what I do. When I sit down at my desk in the morning, I plug it in, and stream music all day. By quitting time, it is fully charged and lasts throughout the evening/night if I need it. Next day, repeat. On the weekend, I'm usually out and about, and the iPad is home, on the charger.
    Again, don't over-think, just enjoy!
    twerppoet likes this.
    221276
    Jun 2012
    France
    26
    Hi and thanks to all, i find the charger plugs gets very hot when charging, is this normal?
    I PAD 16 GO WIFI
    215170
    9 times
    Jun 2012
    Cape Town
    389
    Charging Tips
    The quickest way to charge your iPad is with the included 10W USB Power Adapter. iPad will also charge, although more slowly, when attached to a computer with a high-power USB port (many recent Mac computers) or with an iPhone Power Adapter. When attached to a computer via a standard USB port (most PCs or older Mac computers) iPad will charge, but only when it's in sleep mode. Make sure your computer is on while charging iPad via USB. If iPad is connected to a computer that’s turned off or is in sleep or standby mode, the iPad battery will continue to drain.
    Maximum Battery Life
    To maximize battery life, Apple engineers took the same lithium-polymer battery technology they developed for Mac notebook computers and applied it to the iPad. As a result, you can use iPad for up to 10 hours while surfing the web on Wi-Fi, watching videos, or listening to music. While surfing the web on a 3G data network (Wi-Fi + 3G model), you can get up to 9 hours of battery life.
    Charge Cycles
    A properly maintained iPad battery is designed to retain up to 80% of its original capacity at 1000 full charge and discharge cycles. You may choose to replace your battery when it no longer holds sufficient charge to meet your needs.
    Let It Breathe
    Charging your iPad while in certain carrying cases may generate excess heat, which can affect battery capacity. If you notice that your iPad gets hot when you charge it, take it out of its case first.
    iPad 3
    Charge time is close to 6 hours or more, as it is a bigger battery.
  1. Battery charging
    By Switchatko in forum iPad Help
    Last Post: 03-23-2012, 08:07 AM
  2. Charging a New Battery
    By Solaris in forum iPad General Discussions
    Last Post: 11-03-2010, 09:20 AM
  3. charging the battery
    By Mexicat in forum iPad General Discussions
    Last Post: 07-14-2010, 03:31 AM
  4. Battery charging
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-05-2010, 09:29 PM
  5. iPad battery not charging
    By bbmountain in forum iPad General Discussions
    Last Post: 06-28-2010, 03:37 PM
battery doctor slow to charge ipad3
how often should i charge my ipad 3
ipad 2 leave charging at night
ipad 3 using while charging ok?
ipad battery charging tips
is it bad if you charge your ipad overnight?
is it bad to leave ipad 4 on charger overnight
is it bad to leave ipad charging overnight
is it ok to charge ipad 3 for 6 hrs?
isit bad to charrge ur ipad next to your bed overnigh
leaving ipad 3 charging overnight
ok to charge ipad3 overnight?
