iTunes will back it up before u reinstall
This is a discussion on IPAD 3, Not charging after battery drain.... within the iPad 3 Forum forums, part of the Apple iPad Discussions category; iTunes will back it up before u reinstall...
If it is jailbroken then u can use panda demon app to back it up
I have to put it in DFU mode so I couldn't back it up....![]()
Thanks for thereplies everyone!!!!
Does anyone have any tips for the future because my iPad will runout of battery sometimes and I don't want this to happen ever again...
ANY ADVICE???
Do you have a backup from before the problem started?If so,you could use that and restore from the backup.
No don't have backup.. But do you have any advice for the future???
Yes,always backup on a regular basis in case anything like this ever happens again.
iTunes automatically does a backup, have a look , you might still have the dataOriginally Posted by waffles07
S I already went in preferences and checked and there's only two backups and they arent really proper backups...
