Bluetooth connectivity in general
This is a discussion on Bluetooth connectivity in general within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Coming from Windows/Android world, I'm a bit curious about how bluetooth works in my iPad. It finds my Samsung SGS via BT allright but can't ...
Results 1 to 8 of 8
    216646
    2 times
    Jun 2012
    Cold House, Xibalba
    61
    Coming from Windows/Android world, I'm a bit curious about how bluetooth works in my iPad. It finds my Samsung SGS via BT allright but can't connect to it. Is there something to be done further?
    iPad Addict
    168139
    52 times
    Feb 2012
    Brisbane, Australia
    1,146
    The Bluetooth stack on the iPad and iPhones are limited for security reasons. The main uses are Bluetooth headsets/car kits, Bluetooth keyboards and bluetooth music streaming. General file transfers are locked out to keep the device secure as the iDevices do not apps access a common file system.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    216646
    2 times
    Jun 2012
    Cold House, Xibalba
    61
    Thanks. Hmm, sounds extremely limited... Is it still possible to connect iPad to other iOS devices?
    49720
    277 times
    SC
    5,365
    BT is a lot slower but I have at least two apps that can transfer files over blue tooth. Most would prefer to use wifi if possible .
    iPad Addict
    168139
    52 times
    Feb 2012
    Brisbane, Australia
    1,146
    Quote Originally Posted by theTimo
    I believe Bluetooth is an option for tethering an iPad to an iPhone for the purpose of sharing it's Internet connection. But for the same security reasons, general file transfer is not possible. There are some apps that may give limited transfer ability.
    I also remember that some games can be played multiplayer via Bluetooth, ie. Battleship between iOS devices.
    dhewson777
    Brisbane, Australia
    216646
    2 times
    Jun 2012
    Cold House, Xibalba
    61
    Ok, but this 'security' aspect bugs me still. To me the BT connection is not the unsecure one when compared to wlan connection, for example. When using bluetooth, you pretty much can be sure what you're transferring since the participants are most likely known. With other wireless connections that's not the case always...
    579 times
    Dayton, WA
    13,188
    The security issue is not on the Bluetooth end. It's on having a central file system that any app or remote computer (with the right protocol) can access and modify. Apple has sandboxed it's apps and their files. A sometimes controversial choice, but a fact of life.
    Because of this choice, there is no general file system for Bluetooth to transfer a file too. For this reason (and probably others) Apple does not implement that part of BlueTooth.
    Apps get around this by using the bluetooth serial interface, which Apple does supply an API and support for. But for it to work you need apps running on both devices that look for each other and handle the transfer. Pairing is not needed. But while a few iOS apps do this with each other, I don't know of any developer who has developed the necessary app on both Android and iOS.
    At this time the easiest way to transfer files between an Android and iOS device is a cloud service like DropBox.
    216646
    2 times
    Jun 2012
    Cold House, Xibalba
    61
    Thanks for the answers, folks. Can't help thinking but this is a bit of politics from Apple too..?
    There are limitations also in Android what comes to file formats to be transferred via BT but renaming the only forbidden (apk) file format to something else, you can go around the problem. Of course, there are possible hazards in this if you transfer something from an unfamiliar source, but like I said, that's usually not the case with BT.
  1. Bluetooth connectivity
    By butlerbmx in forum iPad Help
    Last Post: 04-16-2013, 09:28 PM
  2. Replies: 2
    Last Post: 04-05-2012, 11:49 PM
  3. iphone/ipad bluetooth connectivity
    By bins in forum New Member Introductions - Site Assistance
    Last Post: 09-20-2011, 01:58 AM
  4. Bluetooth connectivity
    By mnarracci in forum iPad General Discussions
    Last Post: 07-18-2011, 04:19 PM
  5. Bluetooth connectivity problem
    By Ecocrop in forum iPad Help
    Last Post: 08-10-2010, 09:32 PM
android and ipad communicate through bluetooth
bluetooth between ipad and samsung
bluetooth connect ipad samsung
bluetooth connection between ipad and samsung
can't connect bluetooth to ipad
can't connect to bluetooth ipad
how to connect ipad 3 multiplayer
ios bluetooth battleship
ipad 3 bluetooth connectivity
problem connecting bluetooth on ipad with samsung
samsung bluetooth cant connect ipad
