Results 1 to 3 of 3
    206137
    May 2012
    Denmark
    Using data traffic via mobil using bluetooth instead of buying model with 3G ?
    Hi all.
    My wife wants to buy an iPad 3 and I have a question regarding the need for 3G.
    Is it possible to use data traffic via mobil using bluetooth instead of buying model with 3G ?
    So that the money for the 3G modem in the iPad can be used for data rates on the mobile instead if it is possible to have the iPad use the mobile for data traffic via the bluetooth connection.
    The phone right now are a Sony Ericsson Experia Pro and the carrier are danish Telmore (using TDC network).
    regards
    Christian
    40838
    UK
    81
    Quote Originally Posted by Christian_IA
    Hi all.
    regards
    Christian
    I'm pretty sure data must be over wifi. The experia is an android phone and assuming it's running on 2.1 or above, it will support wifi hotspots. This is where you can set up to 5 devices to connect at any given time.
    You should contact your carrier to determine whether wifi tethering is included in your data allowance, here in the UK it's generally not an issue unless you're on an iPhone contract.
    197308
    Apr 2012
    California
    I use my android phone to throw off a wifi hot spot that the iPad can use.
    I don't know what the mobile phone data charges are like in Denmark...but here in the united states, they have put caps on data for new accounts and a carrier here throttles down speed significantly if you approach what they consider their data limit even if you were grandfathered in.
    So, check with your carrier regarding your data usage and data caps. Otherwise you may be paying for 3G regardless or more, if you go over your allotted data amount.
    As for using data over Bluetooth, I have done this with a blackberry but not an android. With the Bluetooth connection, it was A painfully slow way of Internet connection.
    I would look into perhaps asking your carrier about how much a hot spot wifi is to use on a sporadic basis...as with my experience, most of the time, my iPad is within a free wifi hotspot. It is rare for me to truly need to throw a hot spot from my phone to use my iPad.
  1. Buying a new base model iPad, which is better for my purposes?
    By Stuthedog in forum iPad General Discussions
    Last Post: 03-24-2012, 12:45 AM
  2. Virgin Mobil Top Up Cards ...
    By MelvinTopaz in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-08-2012, 11:57 AM
  3. regarding bluetooth data transferring on ios
    By LiosCheah in forum iPad Hacking
    Last Post: 08-24-2011, 02:12 AM
  4. Problem sincing Bluetooth on 3G model
    By Addicted2it in forum iPad Help
    Last Post: 05-31-2010, 10:52 PM
  5. Problem sincing wi-fi & Bluetooth on 3G model
    Last Post: 05-02-2010, 09:47 AM
android bluetooth ipad 3
bluetooth data from a android phone to an ipad 3
bluetooth data to ipad
bluetooth ipad 3 to android
bluetooth ipad android mobil
data over bluetooth ipad 3
ipad bluetooth data phone
ipad data usage bluetooth
mobile phone charges for ipad bluetooth connection
new ipad bluetooth instead of 3g
use ipad as phone
use ipad as phone bluetooth
Tags for this Thread
