Results 1 to 10 of 15
    204292
    May 2012
    9
    NEWBIE DYING/HELP!!: Ipad 3 stuck in endless recovery loop/ DATA AT RISK.
    have ipad3+5.1.1. Yesterday while browsing it went into recovery mode on its own.
    1. I tried DFU (Redsn0w 09.b2) and recovery mode but it is NOT getting out of recovery mode at all.
    2. I tried Tinyumbrella 5.11, Recboot 2.1 doesnt work.
    Have tons of data NOT backed up. Dont want to lose it..please help me. Its gone into an endless recovery mode loop.
    it is not jailbroken. Latest backup NOT on icloud.
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Sorry to hear of your problem but also confused as I'm not sure why the references to Redsnow and Tinyumbrella are even in your post. There is no jailbreak yet for the new iPad and you state that it isn't jail broken so is there something that we should know about Redsnow and your new iPad that might have possibly caused your lock up issue?
    At this point all I can suggest is allowing the battery to drain and hopefully that will break the recovery loop that you are seeing but there is a very strong chance that you will end up having to restore and restore from backup which means that you will lose whatever new data you have entered since your last backup. Yes I see that it is a lot but I don't know of anything else past DFU mode.
    Good luck!
    204292
    May 2012
    9
    Quote Originally Posted by Mickeylittle View Post
    Good luck!
    thanks for your reply. I dont follow. I was told to try TU and Redsnow by a local techie. Can these be only used when the ipad is jailbroken? Mine is not.
    Should i let in drain while in DFU mode or go to recovery mode and let it drain from there? thanks again
    33347
    12 times
    Feb 2011
    Mississippi
    260
    I am not sure which would be better. Have you tried just the basic reset? While the iPad is on press and hold both the power button and the home button for 10-15 seconds until you see the Apple.
    204292
    May 2012
    9
    yes that was the first thing i did. thats how it ended up in recovery mode i think.
    33347
    12 times
    Feb 2011
    Mississippi
    260
    I've never dealt with this before so just guessing here... But if I was worried about losing a lot of data I would probably try several of those resets back to back to see if it would break free and then if not I would have to allow the battery to drain. Be sure and press the power button for about 10-15 seconds about it has shut completely off to discharge any additional power still in the unit before plugging it back into the charger.
    204292
    May 2012
    9
    when i press + hold power+ home for 10 seconds it goes out and comes back on to recovery mode and then goes out again. does NOT come back on after that even if i am still holding both buttons. so back to back reset not hapenning
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Scared of that...Another option... How close is the nearest Apple store to you? If you have a lot of info you don't wanna lose it maybe worth your time to ride to the Apple store as they may have a way to get this accomplished for you somehow.
    204292
    May 2012
    9
    so u didnt answer the first question. can tinyumbrella or redsn0w only be used in jailbroken devices for recovery?
    33347
    12 times
    Feb 2011
    Mississippi
    260
    I'm not positive as I'm no expert but to my knowledge they are both for jail broken devices. Redsnow is usually what you jailbreak with and Tiny umbrella is a place online where some of your iPad's code is stored so that you don't lose your jailbreaking ability. It ends up getting stored in Cydia. I know I am not wording this correctly as I am going from memory of about 18 months ago.
  1. Clean update but Stuck in Recovery loop
    By yeheey18 in forum iPad Help
    Last Post: 10-07-2011, 01:51 AM
  2. Replies: 6
    Last Post: 09-25-2011, 05:46 PM
  3. Recovery Loop - need help
    By jordan12 in forum iPad Hacking
    Last Post: 07-29-2011, 04:42 AM
  4. iPad 2 4.3.3 recovery loop
    By DontUnderstandMyIpad in forum iPad Hacking
    Last Post: 07-17-2011, 09:27 PM
  5. iPad1 stuck in recovery loop FW 4.3.3
    By maim in forum iPad Hacking
    Last Post: 06-03-2011, 12:34 PM
ipad 3 5.1.1 stuck in dfu mode
ipad 3 apple logo looping
ipad 3 recovery loop
ipad 3 stuck at recovery
ipad 3 stuck in recovery loop
ipad 3 stuck on connect to itunes
ipad endless loop
ipad recovery mode loop
ipad stuck in recovery loop
ipad stuck in restore loop
jailbroken ipad 3 stuck in recovery mode
recovery loop for ipad3
