Hi!I need help!
This is a discussion on Hi!I need help! within the iPad 3 Forum forums, part of the Apple iPad Discussions category; My problem is I have enough money to buy the Ipad3 but I have to wait a month to buy it , I can buy ...
Results 1 to 9 of 9
Thread: Hi!I need help!
    203285
    May 2012
    Venezuela
    Question Hi!I need help!
    Myproblem is I haveenough money tobuytheIpad3butI have to waita monthto buy it, I canbuy theiPad2 now, but i dont know if thats stupid...
    I
    want it to usethe3g, watch moviesand playgames likeInfinityBlade
    tell me what to buy. I think ill buy the Ipad2 cause its cheaper than the Ipad3
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Dude you gotta make your own mind up. Of course the iPad 3 is better than the iPad 2 so if money isn't a problem then get the newest one. Something else to consider is that the iPad 2 is only available in the 16GB version that I know of and that just is not big enough storage for me. Good luck.
    iPF Super Guru
    189057
    93 times
    Apr 2012
    Here, There, Everywhere
    3,536
    Here is my suggestion. Make a list of pros and cons about each iPad model. Decided which one is the one that best suits your wants and needs. I have the iPad2 32GB. It suits me perfectly. Pick what will suit you best. Good Luck!
    49720
    418 times
    SC
    6,343
    I'm going to help you out..keep saving until you can buy the three.
    mini iPad w/ RD - 128 LTE - Space Grey | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
    203370
    May 2012
    Melbourne
    Buy the iPad 3 ( whatever). The retina display alone is worth the extra cost. I love the new model and the minor extra weight is not noticeable. Then buy the iPhoto ap. It is a delight.
    100721
    2 times
    Sep 2011
    85
    Only you can decide and that decision depends critically on how tight your budget is and what you need (want) out of your iPad. I have a 2 and a 3. I didn't have to pay for the 3 with my own money. The 3 is better, but I would have been really upset if I had spent my own money on a tight budget for the difference in the two. I love my 3, but IMHO, you can get a lot of bang for your buck with the 2.
    97693
    858 times
    Sep 2011
    Michigan. USA
    18,178
    Buy the ipad 2 in cash and than charge for the ipad 3. Bring them both home and try them out before your return date expires.
    There you go, than you can have the pleasure of trying both out!
    Just made your decision easier for you, right?
    83420
    2 times
    Jul 2011
    Searcy, AR
    50
    My vote- spend the extra money and get the iPad 3.
    iPhone4S
    iPad 3rd Generation 32GB
    40838
    UK
    81
    I agree with mickeylittle, whatever you decide on I would say the 16gb ipad2 is too small unless you will just surf the net.
    I haven't got the game you mention but if it's anything like a couple I have (asphalt and air supremacy) it'll have nearly a gig footprint on it's own...
    As posted before apps are increasing in size to take advantage of the iPad 3's screen so whilst 16gb a year ago was fine (I had the wifi one) it's a struggle now - my husband now has that one but he mostly uses it for surfing so it's ok for him.
forum hi i need help
husband will only surf net with ipad. which one to get?
ipad 3 16gb big enough
ipad 3 16gb good enough
ipad 3 pros and cons
ipad 3 worth the extra money
ipad 3 worth the money
ipad3 pros and cons
is ipad 3 16gb big enough
is the ipad 3 worth the extra money
pros and cons of ipad 3
pros cons ipad 3 16gb
Tags for this Thread
