Wireless A/N 5GHz Router connection
This is a discussion on Wireless A/N 5GHz Router connection within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I have installed a new home router. It is a Netgear N600 Advanced Dual Band router. I can get the new iPad to connect to ...
Results 1 to 10 of 10
    180142
    Mar 2012
    20
    I have installed a new home router. It is a Netgear N600 Advanced Dual Band router. I can get the new iPad to connect to the G/N 2.4 GHz just fine. But, I can not get the iPad to join the 5GHz band. I have reset the Network Settings, tried running the band with no security etc. I called Apple, and they tried a couple things but it still will not connect. Has anyone connected the iPad 3 to a 5GHz wireless router? Did you by chance notice the channel that the connection used?
    Thanks for any help.
    49720
    411 times
    SC
    6,328
    Quote Originally Posted by Jduckip3
    Don't know the channel but mine works on my netgear 3700 dual band router. I tend to use the 2.4ghz band more, though.
    mini iPad w/ RD - 128 LTE - Space Grey | iPad mini - 64 GB - LTE - Black | iPad (3nd Gen) - 64GB - LTE - Black | iPhone 4S - 64GB - White | Nexus 10 | Nexus 7 2013 | Kindle Fire
    * * * Forum Rules * * *
    180142
    Mar 2012
    20
    Quote Originally Posted by AQ_OC
    Hum, thank you. That is the model I have. Mine works fine on the 2.4, but I can't join the 5. Did you make any changes to the router for that band? I set the SSID, left the channel defaulted to 40, entered the Paraphrase. If you wouldn't mind sometime, would you check the security you selected, and what the default speed and channel that yours is set to.
    I appreciate your answer.
    196878
    4 times
    Apr 2012
    Columbus, GA
    63
    Is it possible to tell the iPad which band to connect to, or does it just connect to the best signal? I also have a dual band router (although not a Netgear), and have noticed that my iPad is connected to the 5 ghz band, while my wife's iPad connects to the 2.4 band.
    180142
    Mar 2012
    20
    Quote Originally Posted by HKey_Current_User
    When I select wifi in Settings, I show both SSIDs. I can select either one. It's strange, the 2.4 starts right up, I get "Unable to Join Network" when I select the 5.
    49720
    411 times
    SC
    6,328
    My 5GHz channel is 48. Mode is upto 300 kbps. Security is WPA2-PSK [AES] . I've been using it flawlessly for months and months. Nary a crash or anything.
    27496
    S. Florida
    35
    Works fine for me too, although the iPad definitely prefers the 2.4Ghz signal -- by that, I mean it usually selects the 2.4Ghz signal as it has a stronger signal. Why are you set on using the 5Ghz band? You really won't notice the difference.
    39127
    4 times
    just outside of philly pa USA
    346
    I have the same netgear router and use the 5.g all the time with out any problems on my iPad 3 the 5 is better for on line gaming
    from USA bucks county pa Sent from my iPad using iPF
    21541
    5 times
    Nov 2010
    Pearl City, Hawaii
    52
    I also have a Netgear WNDR3700, and I use the 5GHz band with no issues. I just gave it it's own unique SSID. Also use WPA2.
    Sent from my iPad 3rd Gen using ipf
    180142
    Mar 2012
    20
    Update: Well as it turns out, it was the iPad. I found an Airport to try to connect to, and could not connect to it as well on the 5ghz side. I went the Apple Store, and they verified the problem. They gave me a new unit, and it connected perfectly. Must have just been something a miss with the wireless hardware.
  1. Can an Ipad be used with a wireless router with no computer hard wired to the router?
    By falcon6 in forum New Member Introductions - Site Assistance
    Last Post: 01-17-2012, 09:26 AM
  2. iPad 2 as wireless 3g router
    By Suranga in forum iPad General Discussions
    Last Post: 06-12-2011, 02:08 PM
  3. Dsl wireless router settings
    By Jde in forum iPad General Discussions
    Last Post: 04-25-2011, 04:11 PM
  4. Mifi wireless router
    By Jasper@xntric in forum iPad General Discussions
    Last Post: 04-10-2011, 03:46 PM
  5. Wireless router
    By whoachubby in forum iPad General Discussions
    Last Post: 07-07-2010, 01:22 PM
can ipad 3 support dual band wireless?
how can i tell if ipad using 5 ghz
ipad 3 5ghz
ipad 3 cannot connect to wifi 5ghz
ipad 5ghz channel
ipad will connect to 5ghz but not 2.4 ghz
ipad wont connect to 5g
wireless capabilities ipad 3 5ghz
