Hi all,
I am looking for some information on the Wifi and bluetooth specifications of ipad2 and ipad3. Details like Band of operation, antenna power, max bandwidth, is it a 1X1 Mimo in both iPads, etc.
Thanks in advance
Aravind
This is a discussion on Wifi capability difference between iPad2 and iPad3 within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi all, I am looking for some information on the Wifi and bluetooth specifications of ipad2 and ipad3. Details like Band of operation, antenna power, ...
Hi all,
Thanks in advance
Aravind
Best I can do for you.
New iPad Tech Specs
Apple - The new iPad - View all the technical specifications.
iPad 2 Tech Specs
Apple - iPad 2 - View the technical specifications for iPad 2.
thanks. But I already went through these, i couldn't find what i was looking for. If someone knows more about the technical details of Wifi implementation, please post it.
Aravind
The only other thing I can suggest is to go to iFixit.com for the breakdowns, and then see what you can find out about the chips. I doubt very much that anyone but an Apple engineer has the kind of detailed specs you want.
iPad 3 4G Teardown - iFixit
