My battery was fully charged when i recieved my ipad?
This is a discussion on My battery was fully charged when i recieved my ipad? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hello. Usually electronic devices ships with 40% charged batteries. When I got mine it was fully charged. Is this how it is?...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    199500
    May 2012
    177736
    20 times
    Mar 2012
    UK
    282
    Quote Originally Posted by larslars View Post
    One can only assume that all new iPads are given a charge at the factory, or perhaps the batteries are already partly charged when fitted, but it's unlikely that every new iPad will be showing the same % charge, as no two batteries will be exactly the same.
    I think mine was at around 70%. Assuming your's was indeed brand new with it's proper sealed shrink wrapping, then all is well.. it's likely a good indication that you possibly have quite a good battery in yours...in that it's holding its charge well. However, if one had a suspicious nature, and it was not a sealed new unit then it may indicate that someone else has given it a full charge.
    199500
    May 2012
    Hey, thanks for comment. It was sealed when I purchased it, so I guess I'm fine. It was also purchased at rather serious store in norway. But I know batteries keep their capacity best if you store them at 40%.
    Lars
    178450
    Mar 2012
    Howard Beach, New York
    I too received mine fully charged from China.
    DSW
    DSW is offline
    194009
    Apr 2012
    My new iPad from the apple store came fully charged so I think it's quite common
    161894
    Feb 2012
    29
    Make the most of your fully charged battery, because it last all of 5 minutes on the new ipad ! The battery life is rubbish
    175581
    Mar 2012
    Michigan
    48
    I got mine on day one, and it was 90+ charged.
    39405
    2 times
    DFW, TX
    141
    Quote Originally Posted by noel1
    "Rubbish" you say? :-)
    Not quite that bad. I would say approx 70-80% of previous gen iPads.
    For the OP, both of our new iPads came with 92% charge on the battery.
    Cheers
    173557
    60 times
    Mar 2012
    537
    My launch iPad (3rd Gen) came in at 85%. My second one three weeks later came in it at 95%.
    I think Apple learned from the iPad 2 that they should ship them as close to a full charge as possible due to having to activate the 3G/LTE side when purchased.
    Facts are the first casualty of bad information.
    192026
    Apr 2012
    Scotland, UK
    10
    My iPad which I bought direct from Apple Store UK arrived with around 93% charge if I'm remembering right. Almost fully charged. I was surprised, and quite happy, as I could start 'playing' with it right away. Nice as most devices arrive mostly discharged and take hours to charge up before you can use them and I'll admit to being a tad impatient especially if it's something I've wanted for a long time and been looking forward to getting.
    As for battery life I get great battery life esp. in comparison to other mobile devices I own. I tend to charge it at night giving it plenty of time to charge up. Which also seems pretty quick, was expecting it to take ages given reviews on line but as I didn't own a previous generation maybe it is a lot slower to recharge, and I have yet to run out of battery life while using it even on days I've been using it for hours that day.
    64GB Black 3rd Generation iPad ~ 8GB Black 3rd Generation iPod Touch ~ 8GB Black 4th Generation iPod Touch
  1. Ipad 3 charged so long
    By rockman in forum iPad 3 Forum
    Last Post: 06-07-2012, 04:10 AM
  2. Replies: 1
    Last Post: 06-22-2011, 12:54 AM
  3. How to tell if Ipad 2 is fully charged?
    By bctf1 in forum iPad 2 Forum
    Last Post: 04-01-2011, 12:18 AM
  4. iPad Battery Always Says "Charged"
    By AlexanderHC in forum iPad Help
    Last Post: 05-16-2010, 04:00 AM
brand new ipad how to start charging
do i need to charge my new ipad before using it
how long do i need to charge my new ipad
how long should you charge a new ipad
how long to charge ipad 3 first time
ipad first charge
ipad first time charge
should charge my new ipad before using
should i charge brand new ipad for 8hrs
should i charge my ipad 3 when i first get it
should i charge my ipad when i first get it
should i charge my new ipad before using
