3G Problem - Could not activate data cellular
This is a discussion on 3G Problem - Could not activate data cellular within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hi. I have the folowing issue with my iPad and I want to know if there's anything I can do to fix it. Every time ...
Results 1 to 6 of 6
    5656
    May 2010
    Caracas
    8
    Question 3G Problem - Could not activate data cellular
    Hi.
    Every time I'm in a bad recepction spot my iPad stops working on 3G. It shows the 3G and provider name but I cannot navigate or get email. I try turning Airplane mode for a couple of minutes and then back of to reset the connections but still nothing.
    The only way to get connection is to turn off and then on the iPad and it gets service again.
    There is any way to avoid this procedure?
    Thank you.
    195160
    Apr 2012
    San Diego, Ca.
    36
    Instead of turning off and on, try turning off/on Cellular Data first.
    iPad 4G LTE
    iMac i5 Desktop
    5656
    May 2010
    Caracas
    8
    Hi.
    Thank you for your reply.
    Tha was my first option but nothing, that's why I tried Airplane mode.
    Thank you again.
    201374
    May 2012
    Ohio
    I am having the same problem with the New IPad - seems to be a global problem. Not very well tested . I have to assume it was released as a known defect. What is Apple saying about this??
    161894
    Feb 2012
    29
    I wish people would stop replying with turn your cellular data on and off/ turn airplane mode on, it just doesnt work until a software update comes out from apple this problem that most of us have when using 3g will persist, the only tempary way around it i find is to turn your ipad off then let it reboot itself it works fine until the next day when you have to go through the same process.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Apple has released IOS version 5.1.1 which supposedly fixed the 3G connection issues. If you are suffering with this problem (and are not interested in jailbreaking) you should update immediately.
  1. Cellular data tab problem
    By abiswas0916 in forum iPad 2 Forum
    Last Post: 04-22-2012, 01:30 PM
  2. No Service "Could not activate cellular data network"
    By ignatzthecat in forum iPad 2 Forum
    Last Post: 04-02-2012, 01:05 PM
  3. Replies: 45
    Last Post: 09-28-2011, 04:54 PM
  4. "Could not activate cellular data network"
    By shark55 in forum iPad General Discussions
    Last Post: 08-15-2011, 11:23 AM
  5. 3g and "Could not activate cellular data network"
    By Rfields987 in forum iPad General Discussions
    Last Post: 06-25-2010, 03:14 PM
could not activate cellular data mode new ipad mobily
could not activate cellular data network ipad
could not activate cellular data network ipad 2
how to activate cellular data network on ipad
how to activate cellular data on ipad
how to activate cellular data on ipad4?
how to enable 3g on ipad 3
how to fix 3g network on ipad
ipad 2 3g could not activate cellular data network
ipad cannot connect to cellular network
ipad could not activate cellular data network
ipad could not activate cellular network
Tags for this Thread
