High speed charging with a 10w charger?
This is a discussion on High speed charging with a 10w charger? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Yesterday I drained my iPad down to 8%.. I wanted to see how long it would take to charge it back to 100%. I did ...
Results 1 to 5 of 5
    196826
    Apr 2012
    14
    Yesterday I drained my iPad down to 8%.. I wanted to see how long it would take to charge it back to 100%. I did some reading and it should take about 12 hours to be absolute 100%.. Since the battery is larger @ 42 watt-hours, vs ipad 2 @ 25 watt-hours. However, if you just want to charge and not do anything on it, Just let it sit there, I found by putting it in Airplane mode speeds up the charging process. It went from 8% to 100% in a 5.5 Hours..
    That's not too bad...
    Just wanted to share my findings...
    Joe
    49720
    277 times
    SC
    5,366
    Quote Originally Posted by Joeteck
    Joe
    Would turning it off speed things even more? 5.5 hours is not bad.
    196826
    Apr 2012
    14
    I tried... It turns on when you plug it in..
    EDIT: You can turn it off when its already pluged in... Now I would have to test this out... !!
    iPad 3 32gig, 4G
    iPhone 4, 16gig
    Motorola Droid Bionic 48gig, 4G
    22588
    2 times
    Nov 2010
    Stuttgart, Germany
    82
    Thanks for the airplane mode info. I usually turn the pad off while it's plugged in to charge overnight.
    Sent from my iPhone 4S or iPad 3rd gen, whichever I happened to have in my hands at the time, using iPF.net
    Apple: "It's not a bug..........it's a feature!"
    11919
    9 times
    Aug 2010
    Virginia, USA
    721
    Mine routinely charges to 100% from that level in around 4 hours or a touch less.
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
  1. Replies: 28
    Last Post: 10-10-2012, 05:49 AM
  2. Replies: 13
    Last Post: 03-20-2012, 09:29 PM
  3. Replies: 9
    Last Post: 10-10-2011, 05:54 PM
  4. Charging speed of USB cable
    By innkuang in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-29-2011, 07:40 AM
  5. iPad charger verses iPhone charger
    By iPadster in forum iPad General Discussions
    Last Post: 01-05-2011, 02:09 PM
high speed charger for ipad
high speed charger ipad
high speed ipad charger
high speed iphone charger
how long does it take to charge an ipad 3
how long does it take to charge an ipad mini
how long does it take to charge ipad 3
ipad 3 high speed charger
ipad high speed charger
ipad speed charger
speed charger ipad
