USB cable not charging the new iPad even though I'm using the factory 10W charger
This is a discussion on USB cable not charging the new iPad even though I'm using the factory 10W charger within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I bought a car charger, a usb plug charger..erm..thingy(plug you put the usb cable into)? and an extra usb cable for my new ipad 3 ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
Like Tree1Likes
Thread: USB cable not charging the new iPad even though I'm using the factory 10W charger
  1. #11
    178386
    Mar 2012
    u.k.
    33
    I bought a car charger, a usb plug charger..erm..thingy(plug you put the usb cable into)? and an extra usb cable for my new ipad 3 in our local pound shop , all in all it cost me 3 quid and they all work fine! (i also got a stand , screen protector and case for it there too!)
  3. #12
    1583
    50 times
    Mar 2010
    Oklahoma
    2,524
    When buying stuff from the internet, caution should be taken. I never buy from Ebay and most others like them. Amazon has usually been good, but you have to read the fine print with items not sold by Amazon. I have a cable that allows me to charge and out put to the car stereo through the 30 pin connector. Apple does not offer such a cable, so I am glad I found one that seems to be to Apple standards.
  4. #13
    39767
    Mount Laurel, NJ
    39
    I just got a couple of these after the aftermarket ones I had for my iPad 2 no longer worked with my new iPad.
    http://eshop.macsales.com/item/NewerTech/CBLUSBDK72/
  5. #14
    103957
    6 times
    Sep 2011
    117
    So here's what I found out... The cables made for the new iPad are actually thicker than the regular 30 pin cables made by apple. I found this out when I tried to plug my new iPad in with an older cable. It wound up saying not charging after about 65%. I held the two up and the one that came with my iPad 3 is noticeably thicker than its elder counterpart. I swapped them out and it worked out fine. Best to keep this in mind if you're anything like me and have 6 different 30 pin cables.
    iPad2 32gb WiFi Green -5.1.1 Jailbroken-
    iPhone 4S 16gb White -5.1.1 Jailbroken-
    iPad3 16gb WiFi White -5.1.1 Jailbroken-
  6. #15
    6127
    2 times
    Jun 2010
    London
    405
    I'm still using the charger & cable from my original iPad 1. I've not even bothered to unpack the charger & cable for the New iPad. It all works fine.
    New iPad wifi + 3G 64GB
    Paired with Macbook Pro
    Backed up to iCloud
  7. #16
    103957
    6 times
    Sep 2011
    117
    Quote Originally Posted by King Hal
    Well, I would expect the iPad cables to work fine with each other however the cables I was using were from iPods I have owned which apparently were a no go.
  8. #17
    172920
    2 times
    Mar 2012
    Chicago NW Suburbs
    52
    I'm using the USB cable that came with my Ipad 3, it charges fine when it's plugged into an outlet, but when I plug into the USB on my PC I get the Not Charging next to the battery symbol. So is it just a problem with the USB cable charging on the computer?
  9. #18
    180142
    Mar 2012
    20
    Quote Originally Posted by af847
    Depends. Some USB ports on pc's do not actually contain a high power source. Generally, these are the front buss USB ports. Generally, the ports on the back are the only powered ports. Plug the same cable in a back port if available and see what happens. This is the way my current HP is configured, and the way my previous Compaq was as well.
  10. #19
    179869
    Mar 2012
    32
    Another tidbit is unless plugged into the wall, the new iPad only charges while the display is off. This is why says not charging while on and plugged in with a computer USB.
  11. #20
    19937
    Nov 2010
    L.A. Co.
    58
    I have a home-built PC using an MSI motherboard. MSI has a utility that works w/some of their motherboards called "SuperCharger". It increases the amperage enough to charge my iPad.
  1. iPad2 factory battery charger questions
    By Cobra Jet in forum iPad 2 Forum
    Last Post: 05-23-2012, 09:40 AM
  2. Good car charger with Aux cable for IPad?
    By Alucard77 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-06-2011, 03:43 PM
  3. Looking for Ipad charging cable 6ft
    By Sshewa1 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-31-2011, 12:29 PM
  4. Replies: 5
    Last Post: 09-08-2010, 02:48 PM
  5. 12V charging cable....OK with iPad ?
    By EODtech in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2010, 10:35 AM
after market new ipad cable not charging 3 meters
ipad 3 cable not charging
ipad 3 not charging
ipad charger cable not working
ipad data cable not charging
ipad not charging with 3rd
ipad not charging with factory charger
ipad won't charge cigarette
ipad won't charge with iphone cord
ipad3 not charging
msi super charger not charging ipad
new ipad not charging
