Ipad 3 battery
This is a discussion on Ipad 3 battery within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Once I got my new iPad the battery has been fantastic. It came with 86% and lasted a couple of days for me. Then I ...
Results 1 to 5 of 5
Thread: Ipad 3 battery
    38205
    2 times
    Derby
    236
    Ipad 3 battery
    Once I got my new iPad the battery has been fantastic. It came with 86% and lasted a couple of days for me. Then I did a first charge and again the battery lasted me 3 days. This morning after a long night in charge I noticed that it was dropping 1% every 5 or 10 mins. Was at 96% before I knew it. I'm not sure how the battery alga rhythm works but I turned it off and on and it's at 100% now. That's where I expected it to be for a while.
    I'm just telling people because on all my iOS devices I've never experienced this.ive never turned my phone off and on for it to go back to a higher battery percentage.
    Sent from my iPad 3
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    this doesn't happen often but I have had it happen with my other iOS devices where turning it off and back on gives it a better reading of the battery and in some cases higher but most of the time lower.
    49720
    278 times
    SC
    5,368
    I've noticed what seemed like some funny behavior with the battery indicator too. I just assume there is some hidden bug in the most recent iOS.
    174776
    5 times
    Mar 2012
    California
    103
    I have installed Boost Magic and System Status. Unless the battery is at 100% or 0, then the percentage of all three could be all over the place but each within 1~3% of each other. And I remember Skull said something about iPad battery indicator is particularly inaccurate at high % due to charging algorithm and battery protection.
    As I write this, my iPad showed 94%, Boost Magic showed 92% and System Status showed 90%. But when it goes down, they gradually converge to the same number. Battery indicator algorithm is just an approximation so don't go to court with your numbers.
    38205
    2 times
    Derby
    236
    Cheers for the replies. I was just curious because it seemed to be dropping at a fast rate. Since turning it off it lasted a while before it dropped to the previous 96%
  1. The New iPad Battery
    By MelvynLoh in forum iPad 3 Forum
    Last Post: 03-17-2012, 10:23 AM
  2. iPad 2 Battery Tip
    By Duckfeet in forum iPad 2 Forum
    Last Post: 06-27-2011, 12:18 AM
  3. Ipad 2 battery
    By Thanhdao in forum iPad Help
    Last Post: 06-21-2011, 05:26 AM
  4. Ipad Battery
    By Romeolo888 in forum iPad General Discussions
    Last Post: 01-11-2011, 07:08 PM
  5. ipad battery
    By Ex Microsoft in forum iPad General Discussions
    Last Post: 01-10-2011, 02:09 AM
first charge ipad 3
initial battery charge ipad 3
ipad 3 battery
ipad 3 battery 86
ipad 3 battery first charge
ipad 3 first battery charge
ipad 3 first charge
ipad 3 initial battery charge
ipad 3 initial charge
ipad battery care
ipad first battery charge
new ipad initial charge
