iTunes Wireless Sync problem
This is a discussion on iTunes Wireless Sync problem within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I've been trying to wireless sync my iPad 3 but it's not working. I have set both the iPad and iTunes to to wireless sync ...
Results 1 to 10 of 15
    175494
    Mar 2012
    So cal
    9
    I've been trying to wireless sync my iPad 3 but it's not working. I have set both the iPad and iTunes to to wireless sync option but it's not working. Also I do have the iPad plugged into an outlet and both of them are on the same network. When I go into the settings>general>iTunes wifi sync the sync now button is greyed out. I've tried to search the forum but couldn't figure out what's wrong. Thanks for the help
    174776
    5 times
    Mar 2012
    California
    103
    This is most under-rated and under-appreciated problem since the iOS 5.0 update. So many moving parts and so little Apple help. Based on my experience, the firewall is the number one suspect; immediately followed by routers settings, assuming everything else has been properly set up.
    Try to turn off the firewall, restart itunes, restart iPad, see if you can get it. if not, Google wifi sync failed or grayed out, you will see tons of threads.
    143197
    Dec 2011
    india
    27
    Hi
    Just trying to help .. If u have already done this ignore the reply...
    1. Connect ur iPad through USB. And select the sync over wifi option .. Apply and come out ...
    2. Remove the IPAD from USB.
    3. Make sure ur iPad is connected over wifi.
    4. Go to settings and general ..click sync now
    5. Plug ur iPad to power source without fail.
    Hope it will work
    If it doesnt work ..
    Check run iTunes on ur comp. check if ur seeing iPad in the devices tab.
    If u see it fine .. Otherwise it means u r not on the same network
    Right click it and do sync now ...
    Hope it will start syncing now ..
    if this happens first time . Form next time it will sync automatically
    Cheers
    144217
    Dec 2011
    39
    WiFi sync is a joke.
    I used to have it working on all three of my devices. It was very slow and very shaky, with devices appearing and disappearing almost randomly at times.
    Now though, none of my devices will even show up via WiFi any more. Nothing has changed and I've checked everything, all is configured properly and no firewalls are in use, it just doesn't work.
    Given that all three devices stopped working simultaneously, I suspect the PC itself and, more specifically, iTunes. I think the only way I'd get it working again is to totally reinstall iTunes but frankly, I can't be bothered. I'll just stick to USB as it's faster and more reliable.
    iPF Expert
    33508
    108 times
    Feb 2011
    Somerset-UK
    7,872
    Totally agree with you. It hasn't worked well from day one for me. It's just easier for me to synch via the wire. It's probably my old Toshiba laptop but no money to replace so I have to put up with it.
    IPad 3 32GB wifi, 2x iphone 4, iPhone 3GS 32GB , ipad 1 32GB ,2x iPod touch 2G, BT keyboard
    All for One and One for All!!!
    From Somerset UK
    174776
    5 times
    Mar 2012
    California
    103
    Quote Originally Posted by Vertigo1 View Post
    Although I experienced the same problem as you and shared the same frustration, I must say that in your setting "SOMETHING" was indeed "CHANGED." And it is likely to be caused by streaming software or network-related stuff that prevent the firewall from behaving properly. I got mine to work beautifully but each time I added a new streaming server on my PC such as VLC Streamer, Air Display, AudioGalaxy, ServetoMe, the Sync is guaranteed to gray out. I had to go through the debugging all over again.
    There are certain firewalls that the Sync won't like such as my AVG. No matter what I did, the AVG firewall simply won't work properly unless I completely shut it down, thus leaving my PC without protection. I switched to Comodo and it was far more flexible and I eventually solve the problem and get it to work for the first time. But then each time I did something, this feature is gone.
    Someone else on Apple Support Forum says they had success with router setting change such as IGMP snooping or Upnp setting. I didn't touch those...
    Debugging is painstakingly tedious. However, if you truly like this feature like I do, then you may wish to spend some time to tweak your firewall or router.
    Like I said originally, this feature is very "un-Apply-like" since it is so un-user-friendly. It was widely reported all over the Internet since iOS 5.0 was first launched and the problem persisted till today and Apple still hasn't figured out a good way to allow the user to systematically solve the problem.
    A lot of people commented that one must "click" the "sync with Wifi" option on the Summary Page in iTune. Although I understand that these folks were trying to help, but each time I read someone said something so stupid, it makes my eyes roll up.
    49720
    277 times
    SC
    5,365
    Wifi sync works for me. Seems to help if the two devices first get to know each other physically first which means connecting via a cable first. After that works well, then the wireless sync tends to work well.
    97693
    501 times
    Sep 2011
    Michigan. USA
    15,275
    Quote Originally Posted by AQ_OC
    I agree-I am performing a wifi sync right now with my iPad. I did the direct connection back in October when the iOS 5 was released-since than, I have only performed a wifi sync. Maybe my iPad has less apps and/or things that can impact the sync process, I don't know-but it has worked well for me!
    I hope you guys can get it sorted out.
    iPad Addict
    29602
    4 times
    London UK
    1,000
    I only managed to sync my iPad 1 on the wifi only once, the first time after I downloaded the iOS 5 point something that allowed wifi syncing. Since then it has never worked and there fore always been using the wire. Infact when the wire is not connected the wifi sync switch us greyed out and only becomes functional when the wire is connected. But the 1st time the sync worked perfectly cause I remember doing it from the bed and the computer was on the table and I could see the process on the iTunes screen and the entire update happened without a wire connection
    iPad 3 Retina, 16gb wifi only
    iPhone 4s 16gb white
    13 inch Macbook Pro i5
    Apple Airport Express
    174776
    5 times
    Mar 2012
    California
    103
    Then you should all be glad that you don't have to go through the agony of mine...
  1. How to enable wireless sync with Windows iTunes
    By frankjg in forum iPad 2 Forum
    Last Post: 01-07-2012, 09:26 AM
  2. iTunes sync problem.
    By epb in forum iPad Help
    Last Post: 11-05-2011, 08:00 PM
  3. Replies: 1
    Last Post: 10-14-2011, 10:02 AM
  4. iTunes Sync problem
    By LVSNE in forum iPad Help
    Last Post: 07-04-2011, 09:55 PM
  5. iTunes sync problem
    By flexismart in forum iPad Help
    Last Post: 12-30-2010, 11:30 AM
ipad itunes wifi sync does not work
ipad mini sync greyed out
ipad not seeing in itunes wifi
ipad wifi sync not working
iphone 5 or ipad3 cannot wifi sync with latest itunes
itunes wifi sync doesnt work
itunes wifi sync greyed out
itunes wifi sync not working
itunes wireless sync not working
since i dowloaded itunes my wifi does not work
why i do t see tabs when sycncing ipad
wireless ipad sync slow
