Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Like Tree1Likes
Thread: iPad 3 Wi-Fi + Verizon LTE Overheat shutdown
  1. #11
    iPad Wizard
    49745
    384 times
    6,683
    Could also involve a power surge, maybe in combo with weak 3G signal, maybe not. I would guess that the power supply from a car would be steadier than household power supply, but I don't know much about car power supplies. They sell home surge protectors, so you could use one at home while charging.
    You also could see if anything appears on your diagnostics log.
    In case you don't know, the iPad diagnostics log is under Settings > About.
  3. #12
    134772
    9 times
    Dec 2011
    Texas
    101
    Quote Originally Posted by Kaykaykay
    An
    Thanks for the info. Didn't know about the diagnostic log. Lots of info there, but the code is a puzzle!
    Some I can make out like timed out or the high temp I had once...
    I'm going to get a repeater to boost my signal.
    Question, is it safe to turn on the reporting errors to Apple?
  1. Ipad 2 shutdown passcode
    By imipadnoob in forum iPad Help
    Last Post: 09-17-2011, 01:51 AM
  2. Ipad shutdown
    By johnmichael in forum iPad Help
    Last Post: 08-17-2011, 06:38 PM
  3. Verizon or AT&T for iPad 2
    By Wakawaka in forum iPad General Discussions
    Last Post: 03-06-2011, 10:39 PM
  4. Ipad for LTE on Verizon
    By screwdriver in forum iPad Carriers
    Last Post: 01-28-2011, 11:35 PM
  5. Shutdown
    By dabirk2 in forum iPad General Discussions
    Last Post: 06-06-2010, 12:10 PM
ipad 3 64gb verizon overheating
ipad 3 heat shutdown
ipad 3 overheat
ipad 3 overheating shutdown
ipad 3 shut down for thermal protection
ipad 3 shutdown during the game
ipad heat shutdown
ipad overheat shutdown
ipad overheating shutdown
ipad shut down suddenly
ipad shutdown heat
shut down new ipad for charging
Tags for this Thread
