Weird Charging Problem
This is a discussion on Weird Charging Problem within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Ive had my iPad since launch a week ago, and the first charge was fine, but I've had to charge it twice since then, and ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    20198
    3 times
    Nov 2010
    Texas
    122
    Ive had my iPad since launch a week ago, and the first charge was fine, but I've had to charge it twice since then, and I have to go through about 5-10 outlets before it'll even start charging (it usually makes the plugged in noise then just says 'Not Charging') and even then it only charges to about 80%. Is anyone else having this problem or know what to do?
    11991
    Aug 2010
    Montreal/Canada
    59
    Are you using the stock charger?
    Any power problem in your home maybe?
    iPhone 4, iPad 3G, apple tv 2gen, 15" MacBook Pro
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    Yeah, you aren't using an iPhone or iPod charger, are you? iPads need a lot of juice and their chargers are specifically designed for them...
    The "Not Charging" message usually means you are using lower powered chargers or USB ports...
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    20198
    3 times
    Nov 2010
    Texas
    122
    Quote Originally Posted by f4780y View Post
    Nope, using the charger that came with the iPad. And never had any problem powering anything else. I don't know what to do lol
    20198
    3 times
    Nov 2010
    Texas
    122
    Bumping for help!
    18454
    15 times
    Oct 2010
    959
    I've read about this problem, sounds like a fault with the iPad, id return it and get a replacement. Have you had an iPad before? If so did it charge ok?
    32GB WIFI/3G 'The New ipad'
    Moderator
    131244
    1420 times
    Dec 2011
    Regina,Canada
    18,518
    Before going to the apple store or or returning the iPad,try running the battery all the way down,then charge it fully.It's possible that the charge indicator needs calibrating.If the problem remains,then by all means return the iPad or go to the apple store for a possible exchange.
    182207
    Mar 2012
    22
    @yakuza, you were using an original ipad charger, but were you using an original ipad cable, the one that came from your package? I had the same problem, & i was using my original ipad 3 charger with a third party cable. It only charged up to 88%. I used my original ipad 3 cable with my original charger, & i was able to charge up to 100%, without the "not charging" message being displayed.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    You definitely should not be getting the "Not Charging" indicator with the official charger. It means either the iPad, Charger, or your home power supply has a problem. Since the 3rd is unlikely, I would take a trip to your nearest Apple Store and get them to look into it for you. They will likely replace it right away.
    20198
    3 times
    Nov 2010
    Texas
    122
    Quote Originally Posted by LeonKaiser View Post
    That actually makes sense, I might have mixed my iPhone and iPad charger cable. I'm gonna try that next time, thanks. If this doesn't help I guess I'm gonna head to the Apple store and see what they say.
  1. Weird ipad only problem
    By aremaitch in forum iPad General Discussions
    Last Post: 02-28-2012, 04:06 PM
  2. Replies: 20
    Last Post: 09-07-2011, 07:59 AM
  3. Very Weird Problem...please help
    By Munky in forum iPad Help
    Last Post: 01-07-2011, 11:54 PM
  4. Jailbreakme.com 3.2.1 Weird problem
    By spiderguy84 in forum iPad Hacking
    Last Post: 08-07-2010, 03:02 AM
  5. Weird battery life problem
    By lowlife in forum iPad General Discussions
    Last Post: 06-09-2010, 04:20 AM
ipad 3 says not charging when plugged in
ipad only charges to 80
ipad only charges to 88
ipad says not charging when plugged in
what does it mean when ipad says not charging
what does it mean when your ipad says not charging
why does my ipad say not charging when i plug it in
why does my ipad say not charging when plugged in
