Power adapter
This is a discussion on Power adapter within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Just bought a new iPad 3 (Love IT!) and I have been using an HP TouchPad. I was wondering if I can use the TouchPad's ...
Results 1 to 3 of 3
Thread: Power adapter
    180839
    Mar 2012
    KC,Mo
    Power adapter
    Just bought a new iPad 3 (Love IT!) and I have been using an HP TouchPad. I was wondering if I can use the TouchPad's usb power adapter (output 5.3 V - 2.0 A) to charge my iPad. I know the iPad's power adapter is 5.1/2.1. Hate to have to spend more money for an Apple adapter if the HP will work...
    Thanks for any replies!
    1583
    50 times
    Mar 2010
    Oklahoma
    2,524
    Short answer - no, if you refer to not charging through the proprietary 30 pin cable. If you are referring to plugging the iPad adapter cord into a USB outlet for another device, then yes, it can be done. Any standard USB charging port can be used to charge the iPad. Due to the large battery, 5w chargers will take forever to charge. A minimum of 10 watts or 2.0 Amps should be the minimum. You get a very good charging device with your iPad. The only thing most people need is to get one for car charging, and they are available at any store that carries electronics.
    180839
    Mar 2012
    KC,Mo
    Thanks Seadog. Really appreciate your quick response. Not using the usb "cable", just the Power adapter that came with the TP. Bought an extra Griffin 10' cable and wanted to use the plug in wall adapter as the power source when traveling. Will keep my eyes open for a Apple car charger. Thanks again.
  1. iPad 2 USB cable and power adapter
    By innkuang in forum iPad 2 Forum
    Last Post: 10-20-2011, 02:21 PM
  2. International Power Adapter For Europe
    By Matth3w in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 09-01-2011, 04:30 AM
  3. 10w power adapter
    By Emodracer in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-12-2011, 12:45 PM
  4. Apple iPad 10W USB Power Adapter
    By Dis2cruise in forum iPad General Discussions
    Last Post: 09-16-2010, 06:17 AM
  5. How does the 10W Power Adapter work
    By vickypt in forum iPad Help
    Last Post: 06-27-2010, 02:41 AM
can i charge ipad with touchpad charger
charge ipod with hp touchpad adapter
hp touchad power adapter ipad
hp touchpad charger ipad
hp touchpad power adapter specs
ipad 3 power adapter specs
output 5.3v 2.0a
power adapter ipad 3
use hp touchpad adapter with ipad
use touchpad charger ipad
