Charger block overheatting?
This is a discussion on Charger block overheatting? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Anyone else getting this? The ac adapter used to charge the new iPad gets so hot it would probably burn me if I held it ...
Results 1 to 5 of 5
    3851
    19 times
    May 2010
    Miami, FL
    2,366
    Anyone else getting this? The ac adapter used to charge the new iPad gets so hot it would probably burn me if I held it for more than a few seconds.
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Did you read what I just posted about the much larger battery size causing the excessive heat on the back on the iPad unit in one of the corners? This is totally related as the charger will take a good 2-3 hours longer to charge the new iPad than it did to charge the iPad 2.
    157881
    15 times
    Jan 2012
    The big tree in your yard.
    334
    yeah mine is pretty hot
    3851
    19 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by Mickeylittle
    I'm not talking about the iPad itself I'm talking about the square brick that you put on the end of the cable used for charging
    33347
    12 times
    Feb 2011
    Mississippi
    260
    Yes sir and I'm talking about both of them. We have 2 different type of heat threads going on right now. Yours is the charging block. Hopefully Apple is aware that their new iPad will give the charging block a run for it's money as it will require an extra 2-3 hours charging time on a daily basis as compared to the old charging block and the iPad 2.
    The other threads are in reference to the heat pouring thru the back of the iPad body where this massage battery is being housed. And the temp changes on it depending on the amount of juice remaining in it and the amount of juice going to it!
  1. New boy on the block
    By crewsta in forum New Member Introductions - Site Assistance
    Last Post: 11-22-2011, 01:03 PM
  2. New Kid On the block!!!
    By deerhunter in forum New Member Introductions - Site Assistance
    Last Post: 09-14-2011, 05:41 AM
  3. new guy on the block
    By tidus10 in forum New Member Introductions - Site Assistance
    Last Post: 02-09-2011, 07:58 PM
  4. New kid on the block!!
    By rkieley in forum New Member Introductions - Site Assistance
    Last Post: 01-07-2011, 05:22 PM
  5. iPad charger verses iPhone charger
    By iPadster in forum iPad General Discussions
    Last Post: 01-05-2011, 02:09 PM
ipad 3 charger hot
ipad ac adapter gets hot
ipad adapter hot
ipad charger burning hot
ipad charger gets burning hot
ipad charger hot
ipad power adapter hot
ipad power supply very hot
