Set up Problem...app content empty..help!
This is a discussion on Set up Problem...app content empty..help! within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Received ipad3 today. Owned the original ipad. Went through setup as new ipad and did not use back up because wanted to start with a ...
Results 1 to 8 of 8
    177527
    Mar 2012
    Michigan
    Received ipad3 today. Owned the original ipad. Went through setup as new ipad and did not use back up because wanted to start with a clean slate. Transferred over my "purchased apps" from Itunes. No content in apps. Now what do I do. For instance. I have a recipe manager. Reinstalled app but how do I now retrieve the 100 recipes I have in there? Any advice is appreciated!
    145
    Jan 2010
    Wheaton, IL
    21
    Quote Originally Posted by Babslanglois View Post
    My guess is that Apple servers are overwhelmed. give it some time. You can attempt restoring you apps from itunes by syncing, but mine did about a half a dozen then disconnected and I can not get a sync started again. I am going to set up for an icloud sync and just let it run overnight and see what happens. I really think that either way it will work when demands on the servers slow down a little bit. good luck.
    3599
    May 2010
    Huntington beach, ca
    14
    Servers were probably overwhelmed. I downloaded the apps from iCloud then synced the machine. Seemed to work okay other than I had to arrange all
    of my folders again. Same as last time. Maybe they'll have things fixed when the "4" or Ipad + comes out
    jhv
    1596
    166 times
    Mar 2010
    4,565
    May I ask did you backup your original iPad before syncing the new iPad? If so the recipes should be there on your computer.
    Cheers Colin,
    Brisbane Australia
    _____________________________
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
    176927
    9 times
    Mar 2012
    Charlotte, NC
    295
    Went through something similar. So I backed up my old iPad again.. Then plugged in the new one.. Right clicked the iPad name on iTunes.. Hit restore from back up.. Chose the old iPad and it added everything back
    177527
    Mar 2012
    Michigan
    Appreciate all the suggestions. I am all set now. What I did was backed up my old to the cloud. Erased and restored the new to factory settings and pulled everything back from the cloud. Ii am good to go.
    Thanks again.
    40838
    UK
    81
    I've got this, but only for pages, think book, ithoughts, phatpad, penultimate, etc are all fine, but the pages isn't.
    Given the old iPad is staying in the house, what's the best way to transfer the documents over?
    I restored my iPad from a backup last night, using iTunes and a cable...
    40838
    UK
    81
    Ok scratch that, went to pages settings and hit restore.
    All is good now..
  1. empty the inbox all at once?
    By brianmackey in forum iPad General Discussions
    Last Post: 07-27-2012, 07:56 PM
  2. Replies: 2
    Last Post: 10-14-2011, 08:30 AM
  3. PDF Files download but have empty content
    By Reader777 in forum iPad Help
    Last Post: 10-12-2011, 06:57 PM
  4. "Erase all Content and Settings" problem
    By quickhick in forum iPad Help
    Last Post: 11-23-2010, 07:17 PM
  5. empty the inbox all at once?
    By brianmackey in forum iPad DIY
    Last Post: 11-09-2010, 07:03 AM
apple ipad 3 setup when transferring from your iphone
how to set up icloud on ipad3
how to start up an ipad3
ipad 3 backup problem
ipad 3 restore original wallpaper
ipad 3 setup
ipad 3 setup issues
ipad 3 setup problems
ipad3 setup
set up email advanced cable and ipad3
setting up ipad 3
where do i set apps content ipadd
Tags for this Thread
