Anyone feel that ipad3 battery dropping faster than ipad2?
This is a discussion on Anyone feel that ipad3 battery dropping faster than ipad2? within the iPad 3 Forum forums, part of the Apple iPad Discussions category; I think it is may be normal that iPad 3 battery drops faster than iPad 2's. And the brightness IMO is also a factor which ...
Page 7 of 8 FirstFirst ... 5 6 7 8 LastLast
Results 61 to 70 of 78
  1. #61
    162254
    6 times
    Feb 2012
    160
    I think it is may be normal that iPad 3 battery drops faster than iPad 2's. And the brightness IMO is also a factor which decides how long the battery will run out after 100% charging.
  3. #62
    Banned
    179253
    Mar 2012
    USA
    25
    As per my iPad 3 battery dropdown faster than iPad 2, but there are some things you should keep in mind which leads you improve your battery problem. Avoid using iPad in hot car or in direct sunlight because this Heat will degrade your battery’s performance the most. And iPad 3 is new one so it’s charging cycles will work differently compare to iPad 2.
  4. #63
    171974
    Mar 2012
    13
    mine doesn't drain faster, but due to the larger battery size it sure does take longer to fully charge.
  5. #64
    175844
    14 times
    Mar 2012
    Vancouver
    466
    Quote Originally Posted by zphone View Post
    This is excellent information, and we need information shared to be able to resolve issues.
    My wireless iPad 3 (no 4g) drops by about 5% at night with only the cover closed. Though a few times it has been much less. So I am pretty sure it's a software issue.
    I have my wifi on all night on it but will try turning that off and see if it has any impact.
    Just reporting back on what I found. YES - Setting airplane mode on at night before bed and just putting smartcover on did it. The battery did not drain at all. Leaving it longer like that without closing out any apps (leaving them in taskbar- but with the iPad on the home screeen) I found that the drain is about 1% per day.
    I will try experimenting further with push/pull mail and see what effect that has as well as turning off most location services. The iPad is not my phone so I don't need those things running on it.
    It's really good to know that the hardware itself is not draining the battery when the iPad is asleep, it's just all those pesky background services.
  6. #65
    182440
    Mar 2012
    Vancouver
    6
    I found mine drained battery when using the smart cover functionality, it was as if it didn't remain in sleep mode even though the screen turned off, I now have the auto sleep with smart cover turned off and have gone old school using the top button as you had to on the original iPad. It no longer drains battery when in sleep mode overnight.
  7. #66
    Banned
    155595
    Jan 2012
    99
    What's a Smart Cover?
  8. #67
    182440
    Mar 2012
    Vancouver
    6
    It's a front cover for the iPad released for iPad 2 onwards, it puts the iPad into sleep mode when closed and automatically wakes the iPad when pulled back.
  9. #68
    175844
    14 times
    Mar 2012
    Vancouver
    466
    Quote Originally Posted by pianoman
    http://www.google.ca/search?hl=en&cl....0.mEPNF4KB748
    It attaches to the iPad with magnets and is really convenient. Great design.
  10. #69
    111727
    Oct 2011
    Columbus, Ohio
    It's still a bummer to plug this new iPad in every night. Sometimes sooner!
  11. #70
    175844
    14 times
    Mar 2012
    Vancouver
    466
    Quote Originally Posted by Mrpete31
    Since I started turning airplane mode on when I leave it for a while it no longer discharges by itself. When I left it last night it had 80% and now I have 80% still after about 12 hours in sleep mode.
  1. iPad3 battery in iPad2 possible?
    By Alex84 in forum iPad 3 Forum
    Last Post: 02-22-2013, 10:54 AM
  2. Buy iPad2 or wait for iPad3?
    By msgtusaf in forum iPad 3 Forum
    Last Post: 04-30-2012, 06:37 PM
  3. I feel so limited with my Ipad2 for business use
    By Filmguy in forum iPad 2 Forum
    Last Post: 10-14-2011, 10:32 PM
  4. Replies: 4
    Last Post: 08-21-2011, 10:03 AM
  5. Apps That Drain Your Battery Faster
    Last Post: 09-29-2010, 11:09 AM
battery goes down fast on ipad
ipad 2 faster than ipad 3
ipad 3 battery
ipad 3 battery drain sleep
ipad 3 runs down fast
ipad 3 uses battery quickly
ipad power runs out too fast
ipad3 losing charge quickly
why does the ipad3 battery drain so fast
why ios6 on ipad3 loses battery very fast
zagg keyboard kills ipad battery
zagg keypad drains my battery
