Help please
This is a discussion on Help please within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hello I was hoping someone could give me some advice, I recently tried replacing my digitiser on my ipad 3 but in doing so I ...
Results 1 to 3 of 3
Thread: Help please
    310564
    Feb 2014
    Help please
    Hello
    I was hoping someone could give me some advice, I recently tried replacing my digitiser on my ipad 3 but in doing so I damaged my wifi antenna and also my power button and volume controls stopped
    working.
    I ordered a new antenna and power assembly and fitted them, the wifi works perfectly but the power
    button still does nothing. I did notice however that when I unseated the ribbon it actually activated th switch making a noise like it had, but when I seated it, it wasn't working, same thing happens when I
    try the original assembly.
    My camera also seems to not work anymore, could this be related to the switch problem. I have checked every ribbon connection and everything seems ok. Also my auto rotate doesn't work.
    Other problems include frequent crashes from most apps and when it crashes I have to plug into
    charger to get it to comeback on, otherwise it gets to the apple logo the crashes continuously. I have
    tried a full restore a couple times to no avail.
    Sorry for going on but it is driving me crazy, should I replace the front and back camera or do you have any other suggestions on what to try or do I just throw it out my window.
    Any help would be appreciated.
    Hashhead.
    Sent using the free mail.com iPad App
    Moderator
    131244
    1405 times
    Dec 2011
    Regina,Canada
    18,481
    If you want to get your iPad 3 working at this point, you should consider taking it to an approved independent repair shop to ask for an estimate. The costs to repair the current damage may make it an uneconomical proposition.
    48665
    934 times
    Brisbane, Australia
    23,440
    Hi and welcome to the Forum!
    My, your list just kept getting longer and I'm wondering if you do start fixing certain things you may find more damage elsewhere.
    Why were you replacing the digitiser in the first place? Was it from a drop of your iPad? If so, maybe damage was caused from this and not just from replacing the digitiser. Was it working before this?
    I tend to agree that there are so many things wrong that it may be a cost prohibitive exercise to undertake regardless.
    You know it may have been a better route to try Apple first.....they've been known to offer a replacement at half the original cost.
    Maybe it's not too late to find out.......
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
