A victim of ios 7 GM installation, please help!!!
This is a discussion on A victim of ios 7 GM installation, please help!!! within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Hello guys, I followed some steps on youtube to install ios 7 GM on my iPad. I did it. Now the software has bugs, it's ...
Results 1 to 10 of 12
Like Tree7Likes
Thread: A victim of ios 7 GM installation, please help!!!
    240728
    2 times
    Aug 2012
    87
    Hello guys, I followed some steps on youtube to install ios 7 GM on my iPad. I did it. Now the software has bugs, it's lagging, dosent respond sometimes. Will I be able to install the real ios 7 on Wednesday 18 th when it comes out considering that my iPad already shows I have ios 7.0.??
    If I can't, what can I do guys to install the correct ios on the 18th, thanks to those are going to help.
    ( iPad 3rd generation , wifi only)
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,052
    Your best bet (well, other than avoiding beta releases ... even GM betas) is to downgrade to iOS 6.1.3.
    And, the easiest way to do that (IMO) is to use this tutorial by my fellow moderator, f4780y: TUTORIAL - Failsafe method to restore the current version of IOS
    If you follow all the steps exactly as written, you should end up with a stock iPad running the newest iOS.
    Hopefully, you've kept your old iOS 6 backup(s), cause you cannot put an iOS 7 backup onto a lower iOS version iDevice. In other words, when you downgrade, you'll have to restore as new when iTunes offers you the option.
    And, final thing - do this ASAP (read: now!) before the official release of iOS 7. Cause yeah, you'll be stuck if you don't ...
    P.S. And I'm sorry, but I'm going to use you as an example: just because you can now get the Gold Master iOS 7 beta without being a developer - does not mean you should try to inSTALL the GM iOS without being a developer. As you can see, it may cause issues...
    J. A., The OB, giradman and 2 others like this.
    240728
    2 times
    Aug 2012
    87
    Thanks for the link, to try that soon.
    1.Well , so does it mean I won't be able to install the new ios on the 18 th?
    2. Second is, say apple release an upgrade to fix something , say "version 7.01", I will be able to upgrade that right? And at the same time maybe fixes the bugs that I have???
    Because I was thinking of not downgrading because I have some data which I am afraid of loosing and to avoid some errors during such processes which may render my device unusable.
    13576
    1445 times
    Aug 2010
    11,052
    I think you'll be able to re-install the new iOS on top of what's on your iPad already. You'll have to use iTunes to do it, you can't do it over-the-air. Just make sure you have the latest version in iTunes before you start the upgrade/re-install.
    I've never dealt with a beta before (I'm not a developer), so I don't know if an update to the iOS will fix your issue(s). You'd think so...
    twerppoet likes this.
    74790
    168 times
    Jul 2011
    Yorkshire,England
    3,601
    Thanks Marilyn.
    Poisonivy
    iPadforums Moderator
    iPhoneforums Administrator
    If you can stay calm while all around you is chaos then you probably haven't understood the seriousness of the situation
    240728
    2 times
    Aug 2012
    87
    Hello guys I am back here, now the restoration can not work here, iTunes is telling it requires iTunes 11.1 which I can't get on my PC, what can I do now.
    48665
    939 times
    Brisbane, Australia
    23,465
    Quote Originally Posted by tsmrg View Post
    I appreciate the problem you do have but please keep all further info on this issue to this thread only as posting in multiple threads makes it confusing for others to follow and is also against our Forum Rules. Your other post on this issue has now been deleted.
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    240728
    2 times
    Aug 2012
    87
    Ok , thanks Mr/Ms admin, I understand. If you have a suggestion for my problem please help. Thank you
    48665
    939 times
    Brisbane, Australia
    23,465
    The best advice I can give you at this point is to follow the advice of Mickey330 who is very knowledgeable on these matters....but right now as you have jumped the gun (so to speak) it would be very hard for anyone to guess at your issues.
    New iTunes versions are also released when a new OS is released. If you do not want to try a downgrade at this point it may be best for you to wait for the genuine release of the new OS.
    Sorry I can't be more helpful at this stage.
    13576
    1445 times
    Aug 2010
    11,052
    Unfortunately, you will not be able to get iTunes 11.1 until iOS 7 is released (so, the 20th).
    Therefore, your best (only?) bet is to wait until then.
    After iTunes 11.1 and iOS 7 are officially released, update your iTunes, connect the iPad and select Restore.
    iTunes should then do it's "magic" and put a fresh iOS 7 on your iPad; one that is hopefully bug-free.
    Again, there is nothing you can do right now as none of the software you need has been officially released. Sorry.
    leelai likes this.
  1. App installation password...
    By iZicle in forum iPad 3 Forum
    Last Post: 06-05-2012, 12:35 PM
  2. Smurfs game victim
    By Bai in forum iPad General Discussions
    Last Post: 11-20-2011, 03:54 PM
  3. New installation of iTunes
    By ajricaud in forum iPad General Discussions
    Last Post: 10-07-2011, 03:24 PM
  4. server installation
    By sonuwa in forum Off-Topic
    Last Post: 07-12-2011, 04:41 PM
do i have to downgrade ios 7 gold master
downgrade 7 gm to 6.1.3
downgrade ios
downgrade ios 7
ios 7 downgrade
ios7 bug
ipad3 downgrade from ios7 t
victim of ios7
