Battery problem
This is a discussion on Battery problem within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Why does my battery go down when I'm charging the iPad and using it at the same time. Shouldn't more. And even when charging alone ...
Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By KevinJS
Thread: Battery problem
    292177
    May 2013
    Battery problem
    Why does my battery go down when I'm charging the iPad and using it at the same time. Shouldn't more. And even when charging alone it takes along time to charged up full.
    85546
    577 times
    Aug 2011
    Edmonton AB Canada
    9,850
    It depends on your use. If you have the screen on maximum brightness and are using processor intensive apps you may find that the charger won't keep up with the draw, particularly if you have the retina display.
    I believe it takes about 12 hours to fully charge a retina display model, even if it is turned off.
    Mickey330 and J. A. like this.
    Apple Equipment (so far) rMBP 15"; iPad 2 (iOS 7.1); iPhone 5s (iOS 7.1); iPhone 4 (iOs 7.1); AirPort Extreme; Airport Express; AppleTV
  1. Problem charging the battery
    By ZammyBoi in forum iPad General Discussions
    Last Post: 09-09-2012, 02:08 AM
  2. battery problem with 4.3.2
    By cemturc in forum iPad 2 Forum
    Last Post: 05-07-2011, 07:47 AM
  3. Battery problem
    By anonchi in forum iPad General Discussions
    Last Post: 04-18-2011, 01:00 AM
  4. Battery problem ?
    By jimfastcar in forum iPad Help
    Last Post: 03-13-2011, 11:52 AM
  5. Battery problem
    By Tootall in forum iPad General Discussions
    Last Post: 01-25-2011, 04:04 PM
ipad retina battery problem
ipad retina charging battery problem
problem in charging ipad retina
