Tweet Sound doesn't work
This is a discussion on Tweet Sound doesn't work within the iPad 3 Forum forums, part of the Apple iPad Discussions category; When I get a tweet sound it doesn't chirp like it used to, it makes a generic notification sound. The Tweet sound is set to ...
Results 1 to 4 of 4
    190625
    Apr 2012
    Los Angeles, CA
    22
    When I get a tweet sound it doesn't chirp like it used to, it makes a generic notification sound. The Tweet sound is set to "Tweet" so I have no idea what to do. Obviously not a big problem just kind of weird.
    1523 times
    Walla Walla, WA
    15,431
    If you are using a third party app like Tweetbot, you may be hearing it's notifications instead, which may use the generic Notification sound.
    190625
    Apr 2012
    Los Angeles, CA
    22
    Using the official twitter app synced with iOS and everything
    1523 times
    Walla Walla, WA
    15,431
    Oh well. No idea why it's misbehaving.
    You could try Settings > General > Reset > Reset All Settings. It's kind of drastic. It wont' erase any data, apps, or accounts, but many of your settings will go back to default; necessitating a careful examination of them all to make sure things go on doing what you expect.
    Though, if you haven't tried a restart or reset yet, you should do those first.
    The usual fixes:
    Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. takes a bit longer than a restart.
    Reset All Settings: Another, somewhat more drastic thing you can do is Reset All Settings. You'll find this under Settings > General > Reset > Reset All Settings. It won't erase any of your content, apps, or accounts; but you will have to go through most of your other settings and re-tweak them back to your liking.
  1. AV Player HD doesn't work
    By ramzes in forum iPad Apps
    Last Post: 03-02-2012, 04:18 PM
  2. iPad2 sound doesn't work without the earphones/headset
    By iRumi in forum New Member Introductions - Site Assistance
    Last Post: 01-06-2012, 06:08 PM
  3. Lost my Tweet Tweet!
    By Expidia in forum iPad 2 Forum
    Last Post: 12-28-2011, 10:02 PM
  4. The app doesn't work right...
    By M325i in forum iPad Apps
    Last Post: 06-14-2011, 09:08 AM
  5. Why doesn't my map work?
    By W4KRR in forum iPad Help
    Last Post: 12-26-2010, 09:15 AM
how to get sound for tweets on ipad
ipad sound doesn't work
tweet sound doesn't work in ios7
tweet sound doesn't work on ipad
twitter sound doesn't work on iphone
why doesn't my twitter sound work on ios 7
why doesn't twitter make tweet sound on ipad
why won't my tweets sound work
