GPS Problems
This is a discussion on GPS Problems within the iPad 3 Forum forums, part of the Apple iPad Discussions category; Have several apps(LivingEarth, TelNav, Sunrise/Sunset) that all require my location from my GPS unit. ( Verizon/64GB/Ipad 3-New) These apps all worked before but now they ...
Results 1 to 6 of 6
Thread: GPS Problems
    190190
    Apr 2012
    Outlet Lower Ugashik Lake Alaska
    14
    GPS Problems
    Have several apps(LivingEarth, TelNav, Sunrise/Sunset) that all require my location from my GPS unit. ( Verizon/64GB/Ipad 3-New) These apps all worked before but now they say they can not get the location from my device. I am not in Airplane mode, Location Services is on and I have tried the reset location & Privacy several times. Any way I can diagnostically check to see if my GPS is still operable or have I overlooked something?
    Thank you for your help
    11919
    9 times
    Aug 2010
    Virginia, USA
    721
    You didn't say, but the presumption is that your iPad is WIFI/3g and not WIFI only.
    What happened after you rebooted?
    If my Irish Wolfhound doesn't like you neither will I.
    2012 13" MBA, 2011 11" MBA, 2010 15" MBP, 2 iPad3s, 1 iPad Mini, iPhone 4S and iPhone 5. A bunch of iPods and an Apple TV.
    49720
    277 times
    SC
    5,365
    Hmm....strange indeed. You have an Verzion iPad 3....Have you tried the built in Apple Maps with your Wifi turned off and cellular turned off? If you open it (be sure you are near a window of even outside), press the little arrow in the lower left and corner...if it zooms into your current location, then your GPS is working. With both Wifi and Cellular off, there is no way for this app to get your locations without the GPS working...
    190190
    Apr 2012
    14
    AQ_OC With WiFi and cellular turned off the built in maps under the Productivity icon find my location. Looks like a problem with the apps to me.
    49720
    277 times
    SC
    5,365
    Quote Originally Posted by UgashikBob View Post
    Have you tried some different apps? Google Earth, maybe? I don't use any of the ones you listed. You can also get the iPhone version of google maps for more testing.
    Also, make sure you have location services set to on for those apps. Look under privacy in settings.
    190190
    Apr 2012
    14
    Have narrowed it down to the Sunrise/Sunset app. In Privacy/Location Services the rest of the apps have the check mark showing that the location has been used but not the Sunrise/Sunset app that used to work. It has a feature where you manually position your location on a map and that works but the auto feature no longer works.
    Thank you for your suggestions.
  1. Some problems
    By majkannan in forum Indian Dedicated iPad Forum
    Last Post: 12-22-2012, 10:16 AM
  2. 4oD problems
    By DC1962 in forum iPad Help
    Last Post: 03-09-2012, 07:29 AM
  3. Os 5 problems
    By rcrcbug in forum New Member Introductions - Site Assistance
    Last Post: 11-26-2011, 06:18 PM
  4. Problems
    By apls64 in forum New Member Introductions - Site Assistance
    Last Post: 10-13-2010, 11:23 AM
  5. iOS 4.2 to 3.2.2 problems
    By Zertuz in forum iPad OS
    Last Post: 10-10-2010, 11:24 AM
gps problems ipad 3
ipad mini gps trouble
maps app lower left beacon
