Screen Scrolling
This is a discussion on Screen Scrolling within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am unable to turn off the voice setting because when in the General settings screen I can not scroll the right hand side of ...
Results 1 to 9 of 9
    268150
    Dec 2012
    Bucks UK
    Screen Scrolling
    I am unable to turn off the voice setting because when in the General settings screen I can not scroll the right hand side of the page to switch off the 'voice' in the accessibility section. any suggestions?
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,055
    Screen Scrolling
    If pressing the arrow to go to the next page doesn't/didn't work (the "arrow" looks like this: > ), then perhaps a restart or reset of ypur iPad is in order. Sometimes iPads need a swift kick in the software. So, when things go weird on the iPad, our first recommendation is to fully close out the offending app and then do a restart or a reset (or both). To do:
    Fully Close an App: Double tap the Home button (or do a 4-finger swipe up) to reveal a row of icons in the multi-tasking bar. Press and hold an icon until they all start to wiggle and you see a red circle with a minus sign ("-") in the top left. Press the minus sign to fully close the app. Don't worry, it won't remove the app from your iPad, just from the iPad's resident memory.
    Then...
    If that doesn't help, try this last step...
    Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    Hopefully that will help. Do let us know how you get on.
    268150
    Dec 2012
    Bucks UK
    hi Marylin;
    Thanks for your suggestion. I had in fact tried a reset which did not work, using the home and power buttons. Nor is the problem linked to a troublesome App. The problem is in my ipad2's 'Settings' Under the Settings > General> Accessibility I turned on, I think they call it, 'Voice Over'. It allows the Ipad to read written text, which worked great. But now I can not turn 'Voice Over' off because when I now select Settings>General I can not scroll down to where Accessability is to turn 'Voice Over' off. Nor can I do a full reset because that selection is below 'Accessability' on the right hand side of the screen. The ipad just refuses to let me scroll down to the bottom of the list on the right hand side of the screen. In the portrait mode I can only see as far as the 'Multitasking Gestures' selection.
    I would welcome any further suggestions.
    13576
    1447 times
    Aug 2010
    11,055
    Screen Scrolling
    Ouch, that is a problem! And, this still happens after you fully close your Settings app and then re-start it?
    If yes, then I'm afraid you're past my expertise. You do have a troublesome app (the Settings app) if fully closing it, then a restart or a reset of the iPad did not fix it.
    Unfortunately, I don't have any more ideas. The only suggestion I can now give is to take it to the Geniuses at an Apple Store. Sorry.
    1523 times
    Walla Walla, WA
    15,432
    Select the last visible option, then swipe down with two fingers.
    Voice Over will start reading each option, scrolling down as it does so.
    Tap on the screen when it gets as far down as you need, then proceed as normal, Voice Over normal, that is tap once to select, then double tap to activate.
    Alternatively, if you set up Triple-click Home, you may be able to triple click the home button and shut off Voice Over from the pop-up menu.
    268150
    Dec 2012
    Bucks UK
    When in portrait mode, in Settings> General> I can just see the upper frame around the ‘Date & Time’ item, and I am able to select it, but Voice Over is not obliging enough to scroll any further down to allow me to select Accessibility. As for Triple-Clicking home, well that control resides in the very place I am trying to access, 'Accessibility'!! Also now realised nor can I swipe, or pinch the screen.
    268150
    Dec 2012
    Bucks UK
    All you techno-files will be disappointed, but my son-in-law, a very bright Irishman, just ripped off the mirrored screen protector, and eureka. Voice Over was banished with a flick of the fingers, and my ipad was fully restored. Thank you to those who gave some thought to my problem, and responded with advise. Clearly we had an operator problem!!
    13576
    1447 times
    Aug 2010
    11,055
    Screen Scrolling
    Good to hear! Every post you made where you couldn't get it to stop was making me hurt!
    Glad you got it sorted. A screen protector ... who knew?
    Thanks for coming back to tell us. It's always good to hear back - especially the success stories.
    1523 times
    Walla Walla, WA
    15,432
    Thanks for the update.
    That would have never occurred to me.
  1. Scrolling through iOS?
    By blackice in forum iPad OS
    Last Post: 07-27-2012, 08:40 PM
  2. Scrolling in the IPF app
    By addiosamigo in forum iPad 3 Forum
    Last Post: 03-21-2012, 07:39 PM
  3. Scrolling not possible sometimes?
    By Coffeeboy in forum iPad Hacking
    Last Post: 08-02-2011, 01:07 PM
  4. Scrolling Issue
    By MikeMurphy in forum iPad General Discussions
    Last Post: 07-31-2011, 01:29 AM
  5. Scrolling
    By sharpaa in forum iPad Help
    Last Post: 07-24-2011, 08:36 AM
