Saving attachments
This is a discussion on Saving attachments within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Is there a way to save attachments to emails on the iPad? Thanks...
Results 1 to 8 of 8
    267624
    Dec 2012
    California
    Saving attachments
    Moderator
    131244
    1416 times
    Dec 2011
    Regina,Canada
    18,505
    Quote Originally Posted by Bob T
    If tha attachment is a PDF file, it can be saved in iBooks. If it is a photograph, it can be saved in the camera roll.
    1523 times
    Walla Walla, WA
    15,432
    If it is something other than a picture, you need an app that will handle that file type.
    Tap and hold on the attachment in Mail for a grid of icons. Your choices, including compatible apps, will be shown. In iOS 5 or earlier you'll get a menu instead. The Open In option shows you the compatible apps.
    Note: If the attachment is outlined with a gray dashed boarder it has not been downloaded yet. Tap it to start the download. When it is finished the boarder will be solid.
    If you were talking about adding attachments to an email, most apps that create or store documents have an email option. Most of the time this is what you would use to send the attachment.
    283811
    Mar 2013
    UK
    I have an Ipad. I am trying to open and save email attachments but they will only open in Quick Look and I cannot save them from here (only options are to print or close). I have downloaded FTP 2 go Pro and iBooks in order to save but when I tap and hold on an attachment the option to "open in" does not appear. Can anyone help???
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by Brian2013 View Post
    What format are the attachments? Attachments can only be opened by apps that are designed to open those attachments, so you need to make sure that you have an app that is designed to work with the type of attachment that you are trying to open.
    283811
    Mar 2013
    UK
    pdfs & powerpoint presentations mostly but also video files etc.
    Brian2013
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Brian2013
    You will probably need a number of apps, for pdf's I'd recommend GoodReader, for PowerPoint, something like Keynote and video files will depend on the format of the videos but OPlayer is always a good bet.
    To be honest, there are many apps for each of your needs, some paid and some free. You will need to take into account if you just want to look at those files or manipulate them in some way but searching in the App Store for "PDF" and your other terms will bring up plenty of options.
    283811
    Mar 2013
    UK
    ok - thanks for this.
    I have downloaded a few programmes which have been recommended but as I mentioned the "open with" option does not appear when I tap and hold on the attachment - any ideas as to why this is not working for me??
    Brian2013
  1. Saving PDF's
    By lmossford in forum iPad General Discussions
    Last Post: 10-03-2012, 03:11 PM
  2. Saving and opening Email attachments
    By N4th4n in forum iPad Help
    Last Post: 11-04-2011, 03:13 PM
  3. saving email attachments.
    By Seed in forum iPad Help
    Last Post: 07-05-2011, 08:33 AM
  4. 3g saving tip, and for those without 3g!
    By Serianni in forum iPad Help
    Last Post: 05-18-2011, 10:12 PM
  5. Saving email attachments
    By walterh1 in forum iPad General Discussions
    Last Post: 06-22-2010, 08:51 PM
how to save an attachment on ipad
how to save attachment on ipad
how to save attachments on ipad
saving an attachment on ipad
saving attachments on an ipad
saving attachments on ipad
