ipad 2 wifi issue
This is a discussion on ipad 2 wifi issue within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Just a few days ago all the wifi networks stopped showing up on my iPad. It doesn't matter where i am, they wont show up ...
Results 1 to 9 of 9
    182811
    Mar 2012
    5
    ipad 2 wifi issue
    Just a few days ago all the wifi networks stopped showing up on my iPad. It doesn't matter where i am, they wont show up anywhere. I'll take my phone out and see like all these networks, they just wont show up on my ipad.
    iPad Addict
    168139
    51 times
    Feb 2012
    Brisbane, Australia
    1,139
    Tried Settings -> Wi-Fi and nothing in the list of networks?
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    182811
    Mar 2012
    5
    yeah nothing shows up, but when i check the networks on my phone they are all there.
    iPad Addict
    168139
    51 times
    Feb 2012
    Brisbane, Australia
    1,139
    Quote Originally Posted by auberry4u
    Hmmm. The only time the list should disappear is when Wifi is turned off. I'm assuming you checked that already.
    dhewson777
    Brisbane, Australia
    182811
    Mar 2012
    5
    yes thats on, my wifi signal has been really poor for a while, no matter what network i connected to, and now nothing even shows up.
    70740
    Jun 2011
    Harrisburg, Pa
    52
    Another thing you might check is to see if airplane mode did not checked by accident.
    iPad Addict
    168139
    51 times
    Feb 2012
    Brisbane, Australia
    1,139
    At this point, I would do all the basic resets for the iPad, starting with clearing the multi task tray (double click the home button, the tray opens at the bottom, hold an icon until it wiggles, then tap the red minus sign on each app in the tray.)
    Then, I would shut down the iPad (hold the power button until the red slider comes up, then slide off). Restart and see how that goes.
    If that does not correct the issue, I would escalate to a hard reset, and after that, a restore.
    If none solve the problem. A trip to an Apple Store might be he next option.
    dhewson777
    Brisbane, Australia
    48665
    479 times
    Brisbane, Australia
    19,094
    Hi and welcome to the Forum!
    Is your 'Ask to join Networks' tab set to ON in your settings? dhewson has the right advice and hopefully this will fix your issues.
    I'll just state a reset here in case you don't know. - Hold the power off button and the home button simultaneously, keep holding them in and you will see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start. Let us know how you go.
    Please do not post twice on your issue as it divides the information given and makes it confusing for members to follow. It is also against our Forum Rules, your other post has now been deleted.
    Tutorial on creating posts on the Forum
    Creating Posts and Starting New Threads - How To
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 64gb 3G
    182811
    Mar 2012
    5
    thanks everyone for your help, I reset my ipad and it works again
  1. Replies: 0
    Last Post: 12-18-2011, 11:24 AM
  2. iPad 2 wifi/3G restore issue
    By cluskey221 in forum iPad Hacking
    Last Post: 08-04-2011, 02:01 PM
  3. Another iPad 2 wifi restore issue from 4.3.4 to 4.3.3
    By Dreamscapeuk in forum iPad Hacking
    Last Post: 07-24-2011, 09:41 AM
  4. Wifi Issue with OS 4.2
    By aramb in forum iPad Help
    Last Post: 12-11-2010, 03:55 PM
