What is "crashing"? Do you mean an app that quits working and blinks to the home screen or do you mean the entire iPad quits working? What exactly happens when it crashes?
This is a discussion on I pad keeps crashing within the iPad 2 Forum forums, part of the Apple iPad Discussions category; What is "crashing"? Do you mean an app that quits working and blinks to the home screen or do you mean the entire iPad quits ...
The entire I pad crashes it will just go blank then the apple logo will come up the it will keep going for about 10 minutes and u can't go back into the iPad it doesn't matter what app I'm in it will still crash dayley
Sounds like a hardware or software problem that should not happen, I would have it checked at an apple store and/ or get a new replacement. My iPad 1 which was inferior then the iPad 2 was nothing as unstable as your iPad 2
iPad 3 Retina, 16gb wifi only
iPhone 4s 16gb white
13 inch Macbook Pro i5
Apple Airport Express
Yes seems you should get it checked out by apple.
