Chargers
This is a discussion on Chargers within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi there Can anyone tell me why the charging cables stop working for no apparent reason. I first used the cable that came with the ...
Results 1 to 3 of 3
Thread: Chargers
    117751
    Oct 2011
    Newcastle, England
    27
    Chargers
    Hi there
    Can anyone tell me why the charging cables stop working for no apparent reason. I first used the cable that came with the ipad 2. That was ok but the cable was shorter than I needed so I bought a 2m cable. This cable worked ok at first but then it stopped, it wouldn't charge no matter what I did. So I had to put up with the shorter one. I tried buying another long one again and exactly the same thing happened. Anyone have any idea why? How can a connector just stop carrying the charge?
    195385
    20 times
    Apr 2012
    122
    Since your charger is working, there is either a break in the cable or the connection to the charger or the iPad is faulty.
    My six foot cable has been working OK, but the wire covering pulled back at the charger exposing the covered wires. Used some super glue after shoving the wire covering into it's mooring again. Apparently some of these cables are not of the best quality. Sounds like you got a couple with borderline wiring quality.
    iPad 2 - iOS 7.1
    117751
    Oct 2011
    Newcastle, England
    27
    Thanks for your reply cruiser111.
    I did think of the connecting wires not firmly fixed somehow but as far as I can see there is no way of checking that without physically damaging the the whole thing. I didnt mention that I had two Ipads, Ipad 1 and Ipad 2. The first charger(the long one) worked on the Ipad 2 but wouldn't work on the Ipad 1. I immediately presumed there was a faulty connection point on the Ipad 1 but couldn't understand why the shorter cabled charger worked on both, but as I said the longer cabled chargers stopped working after a while. Is there a way of checking these charger wirings to the plug? How did you manage to expose your connecting wires?
  1. Different chargers
    By Bdenuto in forum iPad 3 Forum
    Last Post: 08-24-2012, 11:39 PM
  2. what chargers can I use
    By duane518 in forum iPad 3 Forum
    Last Post: 04-09-2012, 05:35 PM
  3. chargers
    By Bonske in forum New Member Introductions - Site Assistance
    Last Post: 03-16-2011, 08:04 AM
  4. Chargers
    By Applephile in forum iPad FAQ
    Last Post: 03-02-2011, 04:13 AM
  5. Car chargers
    By nateccnn in forum iPad General Discussions
    Last Post: 01-06-2011, 04:52 PM
can i use a ipad 3 charger on a ipad 2
how can i tell if ipad charger is faulty?
ipad 3 different charger
ipad faulty chargers
super glue in ipad charging
