Did I kill my wifi antenna?
This is a discussion on Did I kill my wifi antenna? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi I was replacing the digitizer in an ipad and I accidentally ripped the wifi cable a bit. You can see the areas holding it ...
Results 1 to 6 of 6
    262573
    Nov 2012
    Hi I was replacing the digitizer in an ipad and I accidentally ripped the wifi cable a bit. You can see the areas holding it with a screw got ripped off. Since it doesnt appear any wire connections got ripped, I was wondering if it would this still work ok? Looks like its only used for grounding.
    Did I kill my wifi antenna?-dscn0343.jpgDid I kill my wifi antenna?-dscn0346.jpg
    290049
    May 2013
    Italy
    Hi KQ702,
    I also combined the same thing,
    but tell me, how it ended, it still works on WiFi and 3G?
    290510
    May 2013
    Glenrothes, Fife
    I have done the same thing, it appears that my wi-fi is still functioning but the problem is the signal appears to be very weak and I cannot get a signal upstairs anymore.
    I seen there was also a rubber stick pad covering the connection which I believed should be rooted to the frame of the digitizer. I took this pad off and it increased the signal but only slightly, I opened it up again and taped a speaker cable and routed the cable to stick out the side just and no more.
    Looking into the workings of a wi-fi I antenna designs on other products such as laptops the cable antenna cable is routed all the ways around the LCD inside the frame.
    There was a small shiny bit on the inside of the digitizer with a plastic peel off cover on it but it does not align with the connector part on the top of the antenna. I don't know if this was just a manufacturing defect.
    My next thing to try is run a very thin speak cable consisting of 2/3 strands to run all the way round the case and connect as one big loop.
    Also just to drop a bit sold on the damaged grounding pads.
    Most of the above is just based on theory. I work as an engineer for a repair centre of mobile devices and am faced with issues like this quite a lot.
    290315
    3 times
    May 2013
    Peoria, Arizona
    133
    You probably did kill it. Ai yi yi…
    -Samana
    247820
    7 times
    Sep 2012
    Australia
    157
    Google how to repair iPad digitizer or aerial, there are many hits.
    49720
    277 times
    SC
    5,365
    If any metal bits got ripped, you could have done damage.
  1. Over-the-air TV Antenna for iPad
    By xune in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 08-21-2012, 01:55 PM
  2. iPad 2 Wifi antenna flex replaced - Have issues
    By cy2u5 in forum iPad 2 Forum
    Last Post: 05-17-2012, 01:26 PM
  3. Antenna Amplifier??
    By zipur in forum iPad 2 Forum
    Last Post: 03-30-2011, 08:56 PM
  4. Will a skin cause any problems over the 3G antenna?
    By SDM44 in forum iPad General Discussions
    Last Post: 03-09-2011, 11:49 PM
  5. Finally: got my 3G antenna to work..
    By Wetstuff in forum iPad General Discussions
    Last Post: 09-19-2010, 10:41 AM
can i still use ipad 2 antenna
digitizer antenna
i replaced the wifi antenna on my ipad 2 but the wifi doesnt work still
ipad 2 antenna screw ripped
ipad 2 wifi antenna
ipad 2 wifi antenna ripped
ripped ipad 2 wifi
wi fi antenna
wifi antenna signal flex cable replacement for ipad 3 wifi 3rd gen new
wifi cable ipad 2
wifi cable ripped from screws on ipad 2
will my wifi work if i ripped my wifi flex ipad 2
