I need this, where do I get it?
This is a discussion on I need this, where do I get it? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have a translucent silicone cover for the back of my iPad 2. It allows the use of the smart cover and access to all ...
Results 1 to 1 of 1
    54752
    May 2011
    end of dirt road
    41
    I have a translucent silicone cover for the back of my iPad 2. It allows the use of the smart cover and access to all of the controls and ports. The amount of daily grime and stuff from constant travels will not clean off of it and looks really gross. I can use a stiff brush and hot water with soap. It does not look clean enough to suit me even though I know it is clean. I need the same cover in black. I thought I bought the cover from a vendor here on the forum but I can not find them.
    Help please?!?
