Problem with receiving emails
This is a discussion on Problem with receiving emails within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have problem receiving emails in my iPad recently. When I checked Settings and it gave the message "accounts are currently syncing". I did not ...
Results 1 to 2 of 2
    262741
    Nov 2012
    azura_alf@yahoo.com
    I have problem receiving emails in my iPad recently. When I checked Settings and it gave the message "accounts are currently syncing". I did not do any new syncing prior to this problem except resetting the iPad as at that time I had problem playing youtube. I have tried restarting and resetting but the message is still the same. Because of this I am not able to receive any new emails. Has anyone encounter the same problem before and is there any solution? Thanks
    145840
    Jan 2012
    Houston, TX
    Make sure you actually power off the iPad, not just put it in hibernate mode. When you power off correctly, you should get the slider button indicating to Power Off.
    I have found that if something isn't working right, powering off and then powering back on solves 100% of the problems I had.
    Beery
  1. Not receiving all emails on ipad 2
    By bluedeuce in forum iPad 2 Forum
    Last Post: 11-12-2012, 06:09 PM
  2. Receiving emails that won't delete
    By dee1976 in forum iPad Help
    Last Post: 09-04-2012, 08:38 PM
  3. Problem receiving e-mails on iPad after updating iPhone
    By Sunshine girl in forum New Member Introductions - Site Assistance
    Last Post: 07-07-2012, 03:00 PM
  4. Receiving emails with content from other emails
    By Sueann in forum iPad 1 Forum
    Last Post: 04-19-2012, 06:06 AM
  5. Not receiving emails while using cellular
    By pfgoergen in forum iPad Help
    Last Post: 04-06-2012, 08:38 PM
