Cant remember iPad PIN need advice on resetting it
This is a discussion on Cant remember iPad PIN need advice on resetting it within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hello All, I have been going through a process of lcean out and tidying. I tend to re-install my Windows OS every years or so ...
Results 1 to 10 of 14
    262290
    Nov 2012
    London, UK
    7
    Hello All,
    I have been going through a process of lcean out and tidying. I tend to re-install my Windows OS every years or so and clean up and organise my files. In the same process, I thought of adding more security to my iPad, where there was no PIN code in the past I added a PIN code. No I can't remember it. To mak matters worse, as I rebuilt or re installed my PC my iPad is not synched to any PC. I am not so worried about the data, as I have a paid Dropbox account where everything sits. However, I want to know, how can I unlock my iPad? I don't care about the data, I just want to get in. I am happy to reset if I have to. Please help or advise if you can.
    Thanks.
    Ryan
    Moderator
    131244
    636 times
    Dec 2011
    Regina,Canada
    14,656
    Quote Originally Posted by ryanlondonuk
    Hello All,
    Thanks.
    Ryan
    I'm afraid that if you can't remember your password, there is no way of getting past it or of recovering it. You will have to reset it to factory settings, losing anything stored on it. To do so, go to Settings>General>Reset>Erase All Content and Settings. If you don't have a backup, you will have to set it up as a new iPad, adding your apps, music, movies, TV shows and book s from your purchased lists.
    262290
    Nov 2012
    London, UK
    7
    As I said I dont care about losing the data as most of it is on Dropbox. However, even though this PC is not linked or synched with this iPad, will it allow me to go to "Settings>General>Reset>Erase All Content and Settings". Sorry to ask the same question again, are you definitely sure I can reset it with a PC that is not linked or synched with it?
    Moderator
    131244
    636 times
    Dec 2011
    Regina,Canada
    14,656
    You don't need to do it from a PC at all, just do it from settings on the iPad. Once the iPad is erased, and your PC has the latest version of iTunes installed and is authorized on your iTunes account, you can download all the content from your iTunes purchased lists and sync to your iPad to transfer whatever content you choose to your iPad during your first sync.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    Quote Originally Posted by scifan57 View Post
    Except if he can't remember his pin to log in, he can't get to the Settings app...
    262357
    Nov 2012
    5
    Moderator
    131244
    636 times
    Dec 2011
    Regina,Canada
    14,656
    Quote Originally Posted by thewitt
    Correct, in that case, what he has to do is download the latest version of iTunes onto his computer and authorize his computer in his iTunes account. He can. Then connect the iPad to the computer, select his iPad in devices, go into settings and erase all content and settings. Once erased, he can set up his iPad as a new iPad and begin re-downloading the content from the purchased lists.
    262290
    Nov 2012
    London, UK
    7
    scifan57, then that's what I will do. If I have any problems I will let you know. Thanks for all your help.
    262290
    Nov 2012
    London, UK
    7
    Hi, I have downloaded iTunes and authorised the computer but it is not giving a reset option. Please help.
    Moderator
    131244
    636 times
    Dec 2011
    Regina,Canada
    14,656
    Have you connected your iPad to the computer and has iTunes recognized it? Once recognized, you should be able to click on devices and select you iPad. You should then have an option to reset the iPad.
  1. Resetting an iPad
    By lkilgore in forum iPad 3 Forum
    Last Post: 10-30-2012, 01:07 AM
  2. Dangers of Resetting iPad?
    By stooney in forum iPad General Discussions
    Last Post: 02-14-2012, 02:28 PM
  3. Resetting ipad
    By pwood31 in forum iPad Help
    Last Post: 08-16-2011, 08:23 PM
  4. Resetting ipad before selling
    By derm318 in forum iPad General Discussions
    Last Post: 04-24-2011, 12:54 AM
can't remember ipad pin
how to reset ipad pin
ipad forget pin\
ipad pin reset
ipad reset pin
ipad reset pin reset
reset ipad pin
reset ipad with pin
reset ipad without the pin
reset pin in ipad
reset pin ipad
resetting an ipad 2
Tags for this Thread
