Wifi Connectivity
This is a discussion on Wifi Connectivity within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I have the iPad 2 and consistently have wifi connection issues. It constantly disconnects. I have tried turning off wifi and back on, forgetting network, ...
Wifi Connectivity
I have the iPad 2 and consistently have wifi connection issues. It constantly disconnects. I have tried turning off wifi and back on, forgetting network, renewing lease, keeping auto brightness off.....frustration level is through the roof!! No other devices (pc, laptop, iPhones) are having same issue. HELP!
11-20-2012 04:02 PM
Comcast modem with Linksys wireless N router
Moderator
Wifi Connectivity
Originally Posted by
akeys11
You seem to have carried out the right tests. Have you considered connecting up to another router, say an acquaintance's, just to check whether your router/modem is ready for exchange?
Regards, Andrew🐨
iPad Ninja
Hi Akeys11 - I have an iPad 2 and have upgraded to iOS 6.01 - my Wi-Fi connection (home network w/ Linksys router & Time-Warner modem) on the device is occasionally lost (more often than w/ the older iOS; my laptop works fine @ the same time) - as you probably know from searching the web, this has been a common complaint w/ the introduction of this iOS - Apple appears to have solved 'part' of the issue - for more information (and some suggestions to 'repair' your Wi-Fi connection), check out THIS ARTICLE -
AND, if you find a solution(s), please post back - may help others - good luck!
I actually have and it works fine other places and connecting to my wifi hot spot on my iPhone, I'm guessing its the router but I have no clue what settings to mess with. Ideas?
iPad Addict
Do you live close to others with wifi? Sometimes it can be interference which may affect one device more than others. Try switching the channel. Also check to see what frequency your router is using, you can also change the orientation of the router antenna(s) or move the router as the signal may be partially blocked depending on the environment. Is it an older router? Sometimes some devices will respond to a change in the MTU (max transmission unit) but this is normally an 'efficiency' setting that relates to comms between the router and your provider (if your problem is having a connection but no Internet connectivity adjusting this may help or your modem - DSL, cable, satellite etc - may be problematic.
zstairlessone
This is excellent advice and to add to it, you may want to check that the router software is up to date.
I have a user at my location (a workplace0 who seems to have the same sort of problem.... He has an iPad 3 that he says works fine connecting to other wifi networks but when he comes here it will take an extremely long time to connect to our network & once it does connect he cannot access the internet. NOTE: I can connect successfully using both my work laptop (a windows 7 pc) and my personal Android phone. Any suggestions? My network admin is convinced there is no issue with the network itself & I tend to agree since no one else is having this issue here.
- You may not post replies
- You may not edit your posts
Forum Rules
By cruiser111 in forum iPad OS
Last Post: 10-29-2012, 05:54 AM
By JGS14 in forum iPad Help
Last Post: 10-19-2012, 10:39 PM
By jelizp in forum iPad OS
Last Post: 05-19-2012, 08:48 AM
By Diane B in forum iPad 3 Forum
Last Post: 04-05-2012, 01:01 PM
By LeeB in forum iPad Help
Last Post: 07-11-2010, 09:39 PM
connectivity ipad
connexion internet ios6.01
ios 6 wifi disconnect
ios6 wifi disconnecting router mtu
ipad 2 6.01wifi issues
ipad 2? ios 6.01 wifi network disconnect
ipad2 connectivity to timewarner modem
