Email problem
This is a discussion on Email problem within the iPad 2 Forum forums, part of the Apple iPad Discussions category; Hi all, new iPad owners, loving it so far! An email problem just appeared on one of our iPads, when viewing an email, we see ...
Email problem
Hi all, new iPad owners, loving it so far! An email problem just appeared on one of our iPads, when viewing an email, we see the from, to and subject lines but nothing else, the body of the email is not there, just white screen. I've check all the settings I could find and compared to another iPad we have that is working fine.
Help!
11-18-2012 06:45 PM
Email problem
Try the old standard first: close the app fully, then restart or reset the iPad (or both). To do (apologies if you already know):
Fully Close an App: Double tap the Home button (or do a 4-finger swipe up) to reveal a row of icons in the multi-tasking bar. Press and hold an icon until they all start to wiggle and you see a red circle with a minus sign ("-") in the top left. Press the minus sign to fully close the app. Don't worry, it won't remove the app from your iPad, just from the iPad's resident memory.
Then...
If that doesn't help, try this last step...
Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
See if that helped? If not, holler back and we'll take another shot at it. Good luck.
do an hard reboot.. hold home and off botton for about 30 seconds until the apple icon come on screen and release and let it reset.. just a idea..
Or get an app for another mailing box - I`ve removed initial email app from the fav ones.
Email fixed!
Many thanks for your simple fix, resetting the iPad fixed the problem immediately! Have a great thanksgiving!
- You may not post replies
- You may not edit your posts
Forum Rules
By jpinbay in forum iPad 3 Forum
Last Post: 10-10-2012, 12:10 PM
By Alirezagoodarzi in forum iPad 1 Forum
Last Post: 12-26-2011, 05:21 PM
By Leejr71 in forum iPad 2 Forum
Last Post: 11-27-2011, 11:20 AM
By dgerardi in forum New Member Introductions - Site Assistance
Last Post: 11-02-2011, 04:15 PM
By ADubin in forum iPad Help
Last Post: 07-15-2011, 01:08 AM
