I've never had problems viewing videos on websites etc but this morning my iPad wont play anything, I get a message telling me to update my QuickTime or flash player!
How an I update QuickTime?
This is a discussion on QuickTime player for iPad 2 within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I've never had problems viewing videos on websites etc but this morning my iPad wont play anything, I get a message telling me to update ...
Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
Everybody please read the forum rules--->http://www.ipadforums.net/forum-rules-help-info/2119-forum-rules-everybody-please-read.html
iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
Yes, I'm on 6.0.1
Never had this problem before, I'm not trying o view anything different from before either.....![]()
How are you viewing these videos? App used, and site?
If you are using Safari, try going to Settings > Safari and Clear Cookies and Data. You'll have to sign into the sites that usually remember you after doing this.
Also, if you have not done so, try these common fixes.
The usual fixes:
Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart. takes a bit longer than a restart.
