Digitalizer Help??
This is a discussion on Digitalizer Help?? within the iPad 2 Forum forums, part of the Apple iPad Discussions category; I am having some problems with my iPad 2 touch screen there is a part in the screen that stops working or starts acting alone ...
Results 1 to 6 of 6
    257503
    Nov 2012
    Mexico
    5
    Digitalizer Help??
    I am having some problems with my iPad 2 touch screen there is a part in the screen that stops working or starts acting alone it opens apps that are located in that frame of the screen, sometimes it changes from app to app. This doesn't happen always, somedays it works perfect and some days it doesn't. The frame that doesn't work is about one inch wide. I ask around to see what was the problem and they told me that I had to change the digitalizer since my warranty was expired and it cost a lot to buy a new one. I changed the digitalizer and at first it worked fine but then the same problem started the wierd part was that the part of the new screen that didn't work was exactly the same as the old screen. I was wondering if anyone has an idea of what might be happening if the problems is the digitalizer connector.
    257143
    Nov 2012
    AL
    7
    Quote Originally Posted by Javier_gut View Post
    Did the Ipad ever get wet? Could be a short but you should def pop it back open and check the connector.
    257503
    Nov 2012
    Mexico
    5
    Quote Originally Posted by ****_Nasty718
    Thanks for your help, it never go wet but maybe humidity made a short. Do you know if this connector can be fixed or do I have to buy a new one.
    Moderator
    131244
    618 times
    Dec 2011
    Regina,Canada
    14,496
    Try re-seating the connector first.
    257503
    Nov 2012
    Mexico
    5
    Quote Originally Posted by scifan57
    Thanks for your help!!!
    257503
    Nov 2012
    Mexico
    5
    I re-seated the connector and it still not working that part of the sceen could it be a problem with the main board ??
